jQuery UI Widgets Forums Grid Group footer (for sub-totals, etc.)??
This topic contains 8 replies, has 5 voices, and was last updated by  Peter Stoev 6 years, 8 months ago.
  • Group footer (for sub-totals, etc.)?? #7976
    wwest
    Is there a way to show a footer for each group level (that I would use to should sub totals for thet grouping)? Kendo has the concept of a group footer, but jqxgrid is much more feature rich and faster, so I would like to use jqxgrid for this purpose…
    thanks!
    Group footer (for sub-totals, etc.)?? #8017
    Hi wwest,
    The requested functionality is not still supported. At present, it is possible to customize the Group’s header and return custom HTML. If you want to go with this option, you need to use the Grid’s ‘groupsrenderer’ property. It should point to a function which returns the HTML to be rendered.
    Example:
    var groupsrenderer = function (text, group, expanded) {
    return "" + group + "";
    $("#jqxgrid").jqxGrid(
    source: source,
    groupsrenderer: groupsrenderer,
    { text: 'Ship Name', datafield: 'ShipName', width: 250 },
    { text: 'Ship City', datafield: 'ShipCity', width: 100 },
    { text: 'Ship Country', datafield: 'ShipCountry' }
    groupable: true,
    groups: ['ShipCity']
    drv232
    Is this functionality now available for the footer’s?
    Hi drv232,
    No, it is not.
    Group footer (for sub-totals, etc.)?? #102428
    Abbas
    Is Group footer for sub-totals functionality avaiable ?
    Group footer (for sub-totals, etc.)?? #102435
    admin
    The functionality is available in the current version of our Grid component. Demo: https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/grid-grouping-aggregates.htm?material.
    Group footer (for sub-totals, etc.)?? #102452
    Abbas
    I am using the virtualmode: true, Property because we need to create url in rendergridrows .
    We are facing problem Sum of Group total is same as sum of Grand Total .
    Could you please solution
    $(“#grid”).jqxGrid(
    groupable: true,
    selectionmode: ‘singlecell’,
    groupsexpandedbydefault: true,
    showgroupaggregates: true,
    showstatusbar: true,
    showaggregates: true,
    statusbarheight: 25,
    groups: [‘price’],
    virtualmode: true,
    width: ‘100%’,
    Height: ‘100%’,
    var btnDiaryHtml = “”;
    globaldata = obj.data;
    obj.data = Object.keys(obj.data).map(function (key) {
    return obj.data[key];
    if (obj.data.length > 0) {
    $.each(obj.data, function (index, item) {
    obj.data[index].Name = (item.Name || ”);
    return obj.data;
    { text: ‘First Name’, aggregates: [“count”], datafield: ‘firstname’, width: 100 },
    { text: ‘Last Name’, groupable: true, aggregates: [“count”], datafield: ‘lastname’, width: 100 },
    { text: ‘Name’, groupable: true, aggregates: [“count”], datafield: ‘Name’, width: 100 },
    { text: ‘Product’, groupable: true, columntype: ‘dropdownlist’, datafield: ‘productname’, width: 200 },
    { text: ‘Quantity’, datafield: ‘quantity’, aggregates: [“sum”], width: 70, cellsalign: ‘right’ },
    { text: ‘Price’, datafield: ‘price’, aggregates: [“sum”], cellsalign: ‘right’, width: 100, cellsformat: ‘c2’ },
    text: ‘Total’, datafield: ‘total’, aggregates: [“sum”], cellsalign: ‘right’, cellsformat: ‘c2’,
    cellsrenderer: function (row, column, value, defaultRender, column, rowData) {
    if (value.toString().indexOf(“Sum”) >= 0) {
    return defaultRender.replace(“Sum”, “Total”);
    $(“#grid”).jqxGrid({ pageable: false });
    //_gridObject.jqxGrid(‘showgroupsheader’, false);
    $(“#grid”).jqxGrid({ rowsheight: 50 });
    Group footer (for sub-totals, etc.)?? #102453
    Abbas
    Is virtualmode: true, is possible without pageable: true,
    when we set pageable: false,
    getting error
    “grouping” in “virtualmode” without paging is not supported!
    Group footer (for sub-totals, etc.)?? #102459
    Hi Abbas,
    Grouping in virtual mode without paging i.e virtual mode with scrolling is not supported functionality. The reason is that data should be grouped when it’s loaded and in scrolling mode, data is loaded all the time. If we group data loaded on demand, the information displayed in these groups will be wrong as it will group only data from the current view. The sub-totals will be wrong, too because these will be sub-totals of the current view only.
    Peter
