jQuery UI Widgets › Forums › Grid › Grid with JSON data do not work …
This topic contains 7 replies, has 2 voices, and was last updated by Peter Stoev 12 years, 4 months ago.
Hello all …
I am trying to use in my code jqxGrid and nothing is show in th Grid …
The JSON data is in a web service in my database ( you can view data in
http://190.203.221.120:8580/italven90/productosmy code:
var source = { datatype: 'json', datafields: [ { name: 'NRO', type: 'string' }, { name: 'FILA_NRO', type: 'number' }, { name: 'DESC_PROD', type: 'string' }, { name: 'TEXTO_APL', type: 'string' }, { name: 'EXIST', type: 'string' }, { name: 'PRECIO3', type: 'number' }, { name: 'CANTPED', type: 'number' } ], id: 'FILA_NRO', url: "http://190.203.221.120:8580/italven90/productos" };var mi_DA = new $.jqx.dataAdapter(source);$("#jqxProd").jqxGrid( { width: 670, source: mi_DA, theme: 'Classic', columnsresize: true, columns: [ { text: 'Cod. Producto', datafield: 'NRO', width: 200 }, { text: 'Descripcion ...', datafield: 'DESC_PROD', width: 400 } ] });
What I am doing wrong …
Thanks in advance … Armin
Hi arminkesslerw,
The following works on my side:
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.9.0.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var source = { datatype: 'json', datafields: [ { name: 'NRO', type: 'string' }, { name: 'FILA_NRO', type: 'number' }, { name: 'DESC_PROD', type: 'string' }, { name: 'TEXTO_APL', type: 'string' }, { name: 'EXIST', type: 'string' }, { name: 'PRECIO3', type: 'number' }, { name: 'CANTPED', type: 'number' } ], id: 'FILA_NRO', url: 'data.txt' }; var mi_DA = new $.jqx.dataAdapter(source); $("#jqxProd").jqxGrid( { width: 670, source: mi_DA, theme: 'classic', columnsresize: true, columns: [ { text: 'Cod. Producto', datafield: 'NRO', width: 200 }, { text: 'Descripcion ...', datafield: 'DESC_PROD', width: 400 } ] }); }); </script></head><body class='default'> <div id="jqxProd"></div></body></html>
where data.txt is:
[ { "NRO": "7707501", "FILA_NRO": 6196, "DESC_PROD": "A\/V.CLIO DEL.DER.(Electrico S\/Motor)", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 5", "PRECIO3": 204.0000, "CANTPED": 0 }, { "NRO": "7717501", "FILA_NRO": 6197, "DESC_PROD": "A\/V.CLIO IZQ.DEL.(Electrico S\/Motor)", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 9", "PRECIO3": 204.0000, "CANTPED": 0 }, { "NRO": "9923342", "FILA_NRO": 3876, "DESC_PROD": "A\/V.CORSA 2 PTA DER.", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 2", "PRECIO3": 274.0000, "CANTPED": 0 }, { "NRO": "9943343", "FILA_NRO": 3878, "DESC_PROD": "A\/V.CORSA DEL.DER. (4.PTA)", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 27", "PRECIO3": 274.0000, "CANTPED": 0 }, { "NRO": "5423200", "FILA_NRO": 4719, "DESC_PROD": "A\/V.DEL REY DEL.DER.", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 48", "PRECIO3": 182.0000, "CANTPED": 0 }, { "NRO": "7595321", "FILA_NRO": 1500, "DESC_PROD": "A\/V.ELEC.TEMPRA DEL.DER.", "TEXTO_APL": "MIRAGLIO ITALIA", "EXIST": " 16", "PRECIO3": 1127.0000, "CANTPED": 0 }, { "NRO": "7705231", "FILA_NRO": 6194, "DESC_PROD": "A\/V.FIESTA POWER D.DER.(Elec. S\/Motor)", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 6", "PRECIO3": 324.0000, "CANTPED": 0 }, { "NRO": "7715231", "FILA_NRO": 6195, "DESC_PROD": "A\/V.FIESTA POWER DEL.IZQ.(Elec. S\/Motor)", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 10", "PRECIO3": 324.0000, "CANTPED": 0 }, { "NRO": "544132", "FILA_NRO": 7978, "DESC_PROD": "A\/V.GOL DER.(Electrico S\/Motor) 2.PTA 20", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 26", "PRECIO3": 326.0000, "CANTPED": 0 }, { "NRO": "554132", "FILA_NRO": 7979, "DESC_PROD": "A\/V.GOL IZQ.(Electrico\/S\/Motor) 2.PTA 20", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 24", "PRECIO3": 326.0000, "CANTPED": 0 }, { "NRO": "46446908", "FILA_NRO": 1415, "DESC_PROD": "A\/V.PALIO DER. 2 PTA.", "TEXTO_APL": "ZINNI & GUELL", "EXIST": " 12", "PRECIO3": 248.0000, "CANTPED": 0 }, { "NRO": "46446619", "FILA_NRO": 3610, "DESC_PROD": "A\/V.PALIO SIENA DEL.IZQ.(C\/Motor elect )", "TEXTO_APL": "MIRAGLIO ITALIA", "EXIST": " 3", "PRECIO3": 1191.0000, "CANTPED": 0 }]
http://www.jqwidgets.comPeter:
Thanks for your response.
This is my question , the JSON data is absolutely OK. Why do not work with
the URL ?. In my source code is the URL of the data for test.Thanks Armin …
Hi arminkesslerw,
The sample that I sent you works correctly on my side with the latest version of jQWidgets and jQuery Framework. If you would like, I can post the sample online, too.
Could you try the code with the url: “http://190.203.221.120:8580/italven90/productos”
I don’t see errors in my code and when run in the browser the grid is show with column
titles but receive a message : no data to displayThanks and soory by troubles … Armin
Hi arminkesslerw,
The URL that you posted is not working for me. Could you check whether it is correct?
http://www.jqwidgets.comHi Armin,
Do you try to access this data from the same domain i.e from: http://190.203.221.120:8580? I tried the code several times by hosting your file with JSON on our domain and it works as expected. Here’s the sample available online: gridwithjson.htm.
The code is:
<script type="text/javascript"> $(document).ready(function () { var source = { datatype: 'json', datafields: [ { name: 'NRO', type: 'string' }, { name: 'FILA_NRO', type: 'number' }, { name: 'DESC_PROD', type: 'string' }, { name: 'TEXTO_APL', type: 'string' }, { name: 'EXIST', type: 'string' }, { name: 'PRECIO3', type: 'number' }, { name: 'CANTPED', type: 'number' } ], id: 'FILA_NRO', url: 'productos.txt' }; var mi_DA = new $.jqx.dataAdapter(source); $("#jqxProd").jqxGrid( { source: mi_DA, theme: 'energyblue', columns: [ { text: 'Cod. Producto', datafield: 'NRO', width: 200 }, { text: 'Descripcion ...', datafield: 'DESC_PROD', width: 400 } ] }); }); </script>
where productos.txt is your data source.
