jQuery UI Widgets Forums Grid Grid with Buttons on iOS
This topic contains 5 replies, has 3 voices, and was last updated by  seetheo 11 years, 8 months ago.
  • Grid with Buttons on iOS #29058
    ghenne
    I’m creating a grid with buttons in some of the cells.
      Grid1_settings.columns = [
    { text: "Name", dataField: "Name", width: "auto" },
    { text: "", dataField: "B1", width: 45, cellsrenderer: HTMLStop},
    function HTMLStop(id) {
    HTMLStop= "<input type='button' onClick='gridClick(event)' class='gridButton' id='Stop_" + id + "' value='Stop'/>"
    This works fine on the desktop, but not on a iOS device: nothing happens when the button is tapped.
    Any ideas?
    You can try it here:
    http://www.nsbasic.com/i/GridWithButtons
    Grid with Buttons on iOS #29067
    Hi George,
    jQWidgets should be initialized in the jQuery’s document.ready callback. The problem in your page is that they are not initialized correctly. You try to use the widgets, but the JavaScript files are not still loaded.
    Grid with Buttons on iOS #29131
    ghenne
    I’m not sure that’s it. I added some tracing to the code: jqxGrid() is definitely being called after jQuery’s document.ready. I’ve improved the sample at
    If you run it with the Chrome Debugger window open, you can see the sequence of events:
    $(document).ready called
    document.onready called
    Set up and call jqxGrid
    The buttons work fine on the desktop, but not on iOS.
    George
    Grid with Buttons on iOS #29135
    Hi George,
    For displaying Buttons in Cells, use the Button column. See the Popup Editing sample on our website.
    Grid with Buttons on iOS #29146
    ghenne
    That was it!
    Here’s the line of code to create a button in a column:
        { text: "", dataField: "B1", width: 45, columntype: "button",
          cellsrenderer: function () {return "Stop"},
          buttonclick: function (row) {gridButton("Stop", row)}
    Thanks also to RH for the tip!
    Grid with Buttons on iOS #29172
    seetheo
    Is there a way to have more control over the buttonclick event. I would like to have access to the touchstart and touchend events of the button. Also is there a way to directly change the theme of just one button in the column?
    Raphael “Theo” Heard
