jQuery UI Widgets › Forums › Grid › Grid same height as a splitter
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 10 years, 11 months ago.
I’m trying to build a splitter containing a grid, and I want the grid to fit the splitter height and width.
I tried to set the splitters as follows:$(‘#mainSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, panels: [{ size: 200 }] });
$(‘#rightSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, orientation: ‘horizontal’, panels: [{ size: ‘52%’, collapsible: false }] });the grid is inside “rightSplitter” and its settings are:
$("#jqxgrid").jqxGrid( { width: '100%', height: '100px', source: dataAdapter, showfilterrow: true, filterable: true, sortable: true, columnsresize: true, pageable: true, //filtermode: 'excel', localization: getLocalization('en'), autoshowfiltericon: true, showstatusbar: true, renderstatusbar: function (statusbar) { // appends buttons to the status bar. var container = $("<div style='overflow: hidden; position: relative; margin: 5px;'></div>"); var esporta = $("<div style='float: right; margin-left: 5px;'><span style='margin-left: 4px; position: relative; top: 0px;'>Esporta</span></div>"); var stampa = $("<div style='float: right; margin-left: 5px;'><span style='margin-left: 4px; position: relative; top: 0px;'>Stampa</span></div>"); container.append(esporta); container.append(stampa); statusbar.append(container); esporta.jqxButton({ width: 60, height: 20 }); stampa.jqxButton({ width: 65, height: 20 }); // esporta esporta.click(function (event) { $("#jqxgrid").jqxGrid('exportdata', 'xls', 'jqxGrid'); }); // stampa stampa.click(function (event) { var gridContent = $("#jqxgrid").jqxGrid('exportdata', 'html'); var newWindow = window.open('', '', 'width=800, height=500'), document = newWindow.document.open(), pageContent = '<!DOCTYPE html>\n' + '<html>\n' + '<head>\n' + '<meta charset="utf-8" />\n' + '<title>Stampa</title>\n' + '</head>\n' + '<body>\n' + gridContent + '\n</body>\n</html>'; document.write(pageContent); document.close(); newWindow.print(); }); }, columns: [ { text: 'id', datafield: 'id', filtertype: 'textbox', width: 100 }, { text: 'Codice', datafield: 'codice', filtertype: 'textbox', width: 100 }, { text: 'Nome', datafield: 'nome', filtertype: 'textbox', width: 250 }, { text: 'Disponibilità', datafield: 'disponibilita', filtertype: 'checkedlist', filterable: true, width: 180 }, { text: 'Stato', datafield: 'stato', filtertype: 'checkedlist', filterable: true, width: 120 }, { text: 'Localita', datafield: 'localita', filtertype: 'textbox', minwidth: 120 } ], ready: function () { $('#jqxgrid').jqxGrid('hidecolumn', 'id'); addfilter(); //ricarica(1,19); }, });'
But the grid is shown as a line, unless I set the height parameter in pixels and not with a percentage.
Can you help me?
thanksHi joyce973,
We have example with Grid Inside Splitter: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxsplitter/integration-with-jqxgrid.htm?arctic. I would suggest you to follow the same approach.
http://www.jqwidgets.com/Thank you, but what’s wrong in my code? I can’t see that. I’ve noticed that there is no paging in yours. Is this the reason?
Another question, please: is there a way to autosize the splitter box according to the grid height, dynamically?
thank you again
AntonioHi joyce973,
I cannot tell what’s wrong in your code due to the reason that I see only part of it. If you’d like to provide a sample, then please use http://jsfiddle.net/ for that purpose. Regarding your second question: In general, it is vice versa, the Grid’s Size should depend on its Container’s size so I suppose that the answer of your question is no or at least I would not try that.
