jQuery UI Widgets Forums Grid Grid problem with IE8
This topic contains 10 replies, has 2 voices, and was last updated by  Hubert RENAULT 12 years, 7 months ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • Grid problem with IE8 #10896
    HI,
    when I use the option filterable: true it causes this error
    Détails de l’erreur de la page Web
    Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C; .NET4.0E)
    Horodateur : Mon, 12 Nov 2012 16:21:11 UTC
    Message : ‘this.columns[…].columntype’ a la valeur Null ou n’est pas un objet.
    Ligne : 7
    Caractère : 11679
    Code : 0
    URI : http://……………./jqwidgets/jqxgrid.js
    with this code:
    var theme = getTheme();
    { name: ‘Marque’},
    { name: ‘Prix’},
    { name: ‘Kms’},
    { name: ‘Annee’},
    { name: ‘Photo’},
    url: ‘importcardiff/data3.php’
    var imagerenderer = function (row, datafield, value) {
    return ‘‘;
    $(“#jqxgrid1″).jqxGrid(
    width: 560,
    rowsheight: 80,
    showfilterrow: true,
    { text: ”, datafield: ‘Photo’, width: 90, cellsrenderer: imagerenderer },
    { text: ‘Marque Modèle Finition’, filtertype: ‘list’, datafield: ‘Marque’,width: 200},
    { text: ‘Prix’, datafield: ‘Prix’, filtertype: ‘list’, width: 100},
    { text: ‘Kms’, datafield: ‘Kms’, width: 90 },
    { text: ‘Année’, datafield: ‘Annee’, width: 80 },
    var h=(80*)+30;
    $(‘#jqxgrid1’).jqxGrid({ height: h });
    What happen?
    Grid problem with IE8 #10904
    Hi Hubert RENAULT,
    As a solution, remove the { name: ‘Photo’},
    Grid problem with IE8 #10906
    If i do that, the picture doesn’t appear
    Grid problem with IE8 #10907
    There’s a syntax issue here as well: { text: ‘Année’, datafield: ‘Annee’, width: 80 },. Last Items of Arrays should be without ‘,’.
    Grid problem with IE8 #10910
    thank you, I corrected it but no improvement..
    Grid problem with IE8 #10920
    Please provide us a complete small sample which we will be able to run locally and we will fix it for you.
    Grid problem with IE8 #11007
    There is my home page + details.php + sql
    http://wintra.ispa.asso.fr/home.zip
    Grid problem with IE8 #11008
    Hi Hubert RENAULT,
    In the provided code, you didn’t remove the ‘,’ in this line:
    { text: 'Année', datafield: 'Annee', cellsalign: 'center', filtertype: 'list', width: 80 },
    Unfortunately, I wasn’t able to use the sql in the archive to generate a table with columns. There’s only INSERT statement for adding values, but without Create Table.
    Grid problem with IE8 #11011
    excuse me,
    CREATE TABLE `adherents` (
    `ID` int(11) NOT NULL auto_increment,
    `RAISON SOCIALE` text collate utf8_unicode_ci,
    `DIRIGEANT` text collate utf8_unicode_ci,
    `ADRESSE` text collate utf8_unicode_ci,
    `CP` text collate utf8_unicode_ci,
    `VILLE` text collate utf8_unicode_ci,
    `TEL` text collate utf8_unicode_ci,
    `TELECOPIE` text collate utf8_unicode_ci,
    `ACTIVITE` text collate utf8_unicode_ci,
    `EMAIL` text collate utf8_unicode_ci,
    `SITE` text collate utf8_unicode_ci,
    `EMAIL2` text collate utf8_unicode_ci,
    `SITE2` text collate utf8_unicode_ci,
    `EMAIL3` text collate utf8_unicode_ci,
    `SITE3` text collate utf8_unicode_ci,
    PRIMARY KEY (`ID`)
    ) ENGINE=InnoDB AUTO_INCREMENT=61150 DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci AUTO_INCREMENT=61150 ;
    Grid problem with IE8 #11012
    excuse-me again it is the right
    CREATE TABLE `ambulance` (
    `id_ambulance` int(11) NOT NULL auto_increment,
    `identifiant` mediumint(9) NOT NULL,
    `vo` int(11) NOT NULL,
    `type` varchar(10) NOT NULL,
    `marque` varchar(30) NOT NULL,
    `modele` varchar(40) NOT NULL,
    `version` varchar(80) NOT NULL,
    `carrosserie` varchar(20) NOT NULL,
    `nb_porte` int(11) NOT NULL,
    `energie` varchar(20) NOT NULL,
    `boite` varchar(20) NOT NULL,
    `puis_fisc` varchar(2) NOT NULL,
    `puis_din` int(11) NOT NULL,
    `millesime` varchar(4) NOT NULL,
    `circulation` date NOT NULL,
    `kms` int(11) NOT NULL,
    `couleur` varchar(20) NOT NULL,
    `1_main` int(11) NOT NULL,
    `equipement` longtext NOT NULL,
    `prix_pub` varchar(30) NOT NULL,
    `prix_marc` varchar(40) NOT NULL,
    `garantie` varchar(30) NOT NULL,
    `duree` int(11) NOT NULL,
    `sellerie` varchar(30) NOT NULL,
    `coul_int` varchar(30) NOT NULL,
    `photo` text NOT NULL,
    PRIMARY KEY (`id_ambulance`)
    ) ENGINE=MyISAM AUTO_INCREMENT=10 DEFAULT CHARSET=latin1 AUTO_INCREMENT=10 ;
    Grid problem with IE8 #11013
    That’s ok, it works! 🙂
    I remove the “,” at the end of the line
    { text: ‘Année’, datafield: ‘Annee’, cellsalign: ‘center’, filtertype: ‘list’, width: 80 },
    Many thanks
