jQuery UI Widgets Forums Grid grid print converting integer to decimal
This topic contains 3 replies, has 2 voices, and was last updated by  Hristo 8 years, 4 months ago.
  • grid print converting integer to decimal #91869
    shakeel
    When we print a grid having a column with interger values, in the print window its showing those numbers as decimals.
    You can see this issue even in the jqxgrid print demo where the quantity column values are integer in the grid but show as decimals in the print window,
    Shakeel
    grid print converting integer to decimal #91871
    shakeel
    I found that having the cellsformat atrribute set to ‘n’ in the grid layout for that particular column will render it in integer both in th grid as well as the print window.
    grid print converting integer to decimal #91872
    shakeel
    However, if we think about it I still see the issue. Why is it displaying as an integer in the grid and as a decimal in the print window. Shouldn’t it be the same? Not sure why the link isn’t showing up in my first post.
    http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/printing.htm
    Hello shakeel,
    Thank you for the interest to our widget.
    You could add cellsformat: 'n' member to this particular column.
        <title id='Description'>The following example shows how to get the Grid's HTML, add it to a new browser window and trigger printing.</title>
        <script type="text/javascript" src="../../jqwidgets/jqxdata.export.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxgrid.export.js"></script>
                var data = generatedata(10);
                    localdata: data,
                    datatype: "array",
                    datafields:
                        { name: 'date', type: 'date' },
                        { name: 'price', type: 'number' }
                // initialize jqxGrid
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    altrows: true,
                    selectionmode: 'multiplecellsextended',
                      { text: 'First Name', datafield: 'firstname', width: 120 },
                      { text: 'Last Name', datafield: 'lastname', width: 120 },
                      { text: 'Product', datafield: 'productname', width: 177 },
                      { text: 'Available', datafield: 'available', columntype: 'checkbox', width: 67, cellsalign: 'center', align: 'center' },
                      { text: 'Ship Date', datafield: 'date', width: 120, align: 'right', cellsalign: 'right', cellsformat: 'd' },
                      { text: 'Quantity', datafield: 'quantity', width: 70, align: 'right', cellsformat: 'n', cellsalign: 'right' },
                      { text: 'Price', datafield: 'price', cellsalign: 'right', align: 'right', cellsformat: 'c2' }
               $("#print").jqxButton();
                $("#print").click(function () {
                    var gridContent = $("#jqxgrid").jqxGrid('exportdata', 'html');
                    console.log(gridContent);
                    var newWindow = window.open('', '', 'width=800, height=500'),
                    document = newWindow.document.open(),
                    pageContent =
                        '<!DOCTYPE html>\n' +
                        '<html>\n' +
                        '<head>\n' +
                        '<meta charset="utf-8" />\n' +
                        '<title>jQWidgets Grid</title>\n' +
                        '</head>\n' +
                        '<body>\n' + gridContent + '\n</body>\n</html>';
                    document.write(pageContent);
                    document.close();
                    newWindow.print();
            <div id="jqxgrid"></div>
            <div style='margin-top: 20px;'>
                <div style='margin-left: 10px; float: left;'>
                    <input type="button" value="Print" id='print' />
