jQuery UI Widgets Forums Grid grid not populating for initial display
This topic contains 2 replies, has 2 voices, and was last updated by  rrodini 9 years ago.
  • rrodini
    I have a jqxgrid embedded within a pop-up jqxwindow. When the window is first displayed the grid is not populated. When the widow is dismissed and then re-opened the grid is populated. The whole sequence with code that closely matches my production code is here https://www.jseditor.io/?key=jqxgrid-in-jqxwindow-1. Can anyone explain how to get the grid to populate the first time?
    Hi rrodini,
    Several problems in this code:
    1. HTML Structure for the Window is incorrect. You put the Grid in the window’s header.
    Correct code below:
    <HTML>
    	<HEAD>
    	</HEAD>
    	<BODY>
    	    <!-- pop up window -->
            <div id='jqxwindow'>
                <div>Title</div>
                <div>
                    <div id="jqxtree" style="float: left; "></div>
                    <div id="jqxgrid"></div>
                <div>
                    <button id='cancel'>Cancel</button>
                    <button id='ok'>Okay</button>
            <button id='button'>Open Window</button>
    	</BODY>
    </HTML>
    2. The code for loading data in the Grid is called before the Grid is created i.e it tries to load data in something which does not exist. Correct code below:
    function loadGrid() {
        var data = new Array();
        var firstNames = [
        var lastNames = [
        var productNames = [
        var priceValues = [
        for (var i = 0; i < 100; i++) {
            var row = {};
            row["price"] = price;
            row["quantity"] = quantity;
            data[i] = row;
        var datasource = {
            localdata: data,
            datatype: "array"
         var dataAdapter = new $.jqx.dataAdapter(datasource, {
             loadComplete: function(data) {},
             loadError: function(xhr, status, error) {}
        $('#jqxgrid').jqxGrid(
            {source: dataAdapter}
        $("#jqxwindow").jqxWindow({
            isModal: true,
            autoOpen: false,
            height: 500,
            width: 650,
            theme: 'energyblue',
            cancelButton: $('#cancel'),
            okButton: $('#ok'),
            initContent:
                function() {
                    $("#jqxtree").jqxTree({
                        width: 275,
                        height: 400,
                        source: null,
                    $("#jqxgrid").jqxGrid({
                        width: 275,
                        height: 400,
                        source: null,
                        columns: [{
                            text: 'First Name',
                            datafield: 'firstname',
                            width: 100
                            text: 'Last Name',
                            datafield: 'lastname',
                            width: 100
                            text: 'Product',
                            datafield: 'productname',
                            width: 180
                            text: 'Quantity',
                            datafield: 'quantity',
                            width: 80,
                            cellsalign: 'right'
                            text: 'Unit Price',
                            datafield: 'price',
                            width: 90,
                            cellsalign: 'right',
                            cellsformat: 'c2'
                            text: 'Total',
                            datafield: 'total',
                            width: 100,
                            cellsformat: 'c2'
                             loadGrid();
            $('#cancel').jqxButton({width: '50'});
                    $('#ok').jqxButton({width: '50'});
        $('#button').on('click', function() {
            $('#jqxwindow').jqxWindow('open');
    rrodini
    Thanks for pointing out the html error. You made me think about the initialization process and the critical error in initContent was setting ‘source: null’ for the jqxTree. Once I deleted that line things starting working as I expected. Thanks for the feedback.
