jQuery UI Widgets › Forums › Grid › grid with 3.2.1
This topic contains 3 replies, has 2 voices, and was last updated by Dimitar 11 years, 5 months ago.
Authorgrid with 3.2.1 Posts
Hi
Recently i have downloaded 3.2.1,
before : i have initialized grid with out source attribute, but loading data into grid as and when required, works fine.
now : same code, but grid status bar appearing underneath of header of grid, as grid is empty even no source as mentioned above.
Hello mallepaddi,
We could not reproduce the reported issue. Please try out the following example. Do you experience any issues with it?
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxwindow.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var getAdapter = function () { // prepare the data var data = generatedata(15); var source = { localdata: data, datatype: "array", datafields: [ { name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'quantity', type: 'number' }, { name: 'price', type: 'number' }, { name: 'available', type: 'bool' } ], updaterow: function (rowid, rowdata, commit) { // synchronize with the server - send update command // call commit with parameter true if the synchronization with the server is successful // and with parameter false if the synchronization failed. commit(true); } }; var dataAdapter = new $.jqx.dataAdapter(source); return dataAdapter; } // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 680, autoheight: true, // source: getAdapter(), showstatusbar: true, renderstatusbar: function (statusbar) { // appends buttons to the status bar. var container = $("<div style='overflow: hidden; position: relative; margin: 5px;'></div>"); var addButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' src='../../images/add.png'/><span style='margin-left: 4px; position: relative; top: -3px;'>Add</span></div>"); var deleteButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' src='../../images/close.png'/><span style='margin-left: 4px; position: relative; top: -3px;'>Delete</span></div>"); var reloadButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' src='../../images/refresh.png'/><span style='margin-left: 4px; position: relative; top: -3px;'>Reload</span></div>"); var searchButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' src='../../images/search.png'/><span style='margin-left: 4px; position: relative; top: -3px;'>Find</span></div>"); container.append(addButton); container.append(deleteButton); container.append(reloadButton); container.append(searchButton); statusbar.append(container); addButton.jqxButton({ width: 60, height: 20 }); deleteButton.jqxButton({ width: 65, height: 20 }); reloadButton.jqxButton({ width: 65, height: 20 }); searchButton.jqxButton({ width: 50, height: 20 }); // add new row. addButton.click(function (event) { var datarow = generatedata(1); $("#jqxgrid").jqxGrid('addrow', null, datarow[0]); }); // delete selected row. deleteButton.click(function (event) { var selectedrowindex = $("#jqxgrid").jqxGrid('getselectedrowindex'); var rowscount = $("#jqxgrid").jqxGrid('getdatainformation').rowscount; var id = $("#jqxgrid").jqxGrid('getrowid', selectedrowindex); $("#jqxgrid").jqxGrid('deleterow', id); }); // reload grid data. reloadButton.click(function (event) { $("#jqxgrid").jqxGrid({ source: getAdapter() }); }); // search for a record. searchButton.click(function (event) { var offset = $("#jqxgrid").offset(); $("#jqxwindow").jqxWindow('open'); $("#jqxwindow").jqxWindow('move', offset.left + 30, offset.top + 30); }); }, columns: [ { text: 'First Name', columntype: 'textbox', datafield: 'firstname', width: 90 }, { text: 'Last Name', datafield: 'lastname', columntype: 'textbox', width: 90 }, { text: 'Product', datafield: 'productname', width: 170 }, { text: 'In Stock', datafield: 'available', columntype: 'checkbox', width: 125 }, { text: 'Quantity', datafield: 'quantity', width: 85, cellsalign: 'right', cellsformat: 'n2' }, { text: 'Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2' } ] }); // create jqxWindow. $("#jqxwindow").jqxWindow({ resizable: false, autoOpen: false, width: 210, height: 180 }); // create find and clear buttons. $("#findButton").jqxButton({ width: 70 }); $("#clearButton").jqxButton({ width: 70 }); // create dropdownlist. $("#dropdownlist").jqxDropDownList({ autoDropDownHeight: true, selectedIndex: 0, width: 200, height: 23, source: [ 'First Name', 'Last Name', 'Product', 'Quantity', 'Price' ] }); if (theme != "") { $("#inputField").addClass('jqx-input-' + theme); } // clear filters. $("#clearButton").click(function () { $("#jqxgrid").jqxGrid('clearfilters'); }); // find records that match a criteria. $("#findButton").click(function () { $("#jqxgrid").jqxGrid('clearfilters'); var searchColumnIndex = $("#dropdownlist").jqxDropDownList('selectedIndex'); var datafield = ""; switch (searchColumnIndex) { case 0: datafield = "firstname"; break; case 1: datafield = "lastname"; break; case 2: datafield = "productname"; break; case 3: datafield = "quantity"; break; case 4: datafield = "price"; break; } var searchText = $("#inputField").val(); var filtergroup = new $.jqx.filter(); var filter_or_operator = 1; var filtervalue = searchText; var filtercondition = 'contains'; var filter = filtergroup.createfilter('stringfilter', filtervalue, filtercondition); filtergroup.addfilter(filter_or_operator, filter); $("#jqxgrid").jqxGrid('addfilter', datafield, filtergroup); // apply the filters. $("#jqxgrid").jqxGrid('applyfilters'); }); }); </script> </head> <body class='default'> <div id='jqxWidget'> <div id="jqxgrid"> </div> <div id="jqxwindow"> <div> Find Record</div> <div style="overflow: hidden;"> <div> Find what:</div> <div style='margin-top: 5px;'> <input id='inputField' type="text" class="jqx-input" style="width: 200px; height: 23px;" /> </div> <div style="margin-top: 7px; clear: both;"> Look in:</div> <div style='margin-top: 5px;'> <div id='dropdownlist'> </div> </div> <div> <input type="button" style='margin-top: 15px; margin-left: 50px; float: left;' value="Find" id="findButton" /> <input type="button" style='margin-left: 5px; margin-top: 15px; float: left;' value="Clear" id="clearButton" /> </div> </div> </div> </div> </body> </html>
http://www.jqwidgets.com/HI
When grid is wrapping between <form> tag and it’s not aligning when executing at server side.
Hi mallepaddi,
Is this the same issue you have resolved in the forum topic Expander & grid in IE?
