jQuery UI Widgets Forums Grid Grid – Issue using popupedit
This topic contains 6 replies, has 3 voices, and was last updated by  Peter Stoev 12 years, 1 month ago.
  • Grid – Issue using popupedit #18863
    Keshavan
    I have implemented popup edit in grid, while all is Ok, modified values don’t appear in main grid. Is it issue with ‘Cellendedit’,
    i followed the sample, but i have said issue. Please help.
    I have pasted code below,
    Keshavan
    In order to enter in edit mode, click any of the ‘Edit’ buttons.
    To save the changes, click the ‘Save’ button in the popup dialog. To cancel the
    changes click the ‘Cancel’ button in the popup dialog.
    var theme = getDemoTheme();
    // prepare sample data.
    var data = {};
    var generaterow = function (id) {
    var row = {};
    row[“GroupCompanyId”] = id;
    row[“GroupName”] = ” “;
    row[“Miscellaneous1″] = ” “;
    row[“Culture”] = ” “;
    return row;
    { name: ‘GroupCompanyId’ },
    { name: ‘GroupName’ },
    { name: ‘Miscellaneous1’ },
    { name: ‘Culture’ },
    url: ‘GroupCompany/GetGroupCompanies’,
    // synchronize with the server – send insert command
    cache: false,
    dataType: ‘json’,
    url: ‘GroupCompany/Add’,
    data: rowdata,
    type: “POST”,
    commit(true);
    alert(errorThrown);
    commit(false);
    // synchronize with the server – send delete command
    dataType: ‘json’,
    cache: false,
    url: ‘/GroupCompany/Delete/5’,
    type: “POST”,
    // delete command is executed.
    commit(true);
    alert(jqXHR.statusText);
    commit(false);
    $.ajax(
    cache: false,
    dataType: ‘json’,
    url: ‘GroupCompany/Update’,
    data: rowdata,
    type: “POST”,
    alert(success);
    commit(true);
    alert(errorThrown);
    commit(false);
    // initialize the input fields.
    $(“#GroupName”).jqxInput({ theme: theme });
    $(“#Miscellaneous1”).jqxInput({ theme: theme });
    $(“#culture”).jqxInput({ theme: theme });
    $(“#GroupName”).width(375);
    $(“#GroupName”).height(23);
    $(“#Miscellaneous1”).width(375);
    $(“#Miscellaneous1”).height(23);
    $(“#culture”).width(20);
    $(“#culture”).height(23);
    var editrow = -1;
    // initialize jqxGrid../../JqWidgets/index.htm
    $(“#jqxgrid”).jqxGrid(
    width: 950,
    height: 350,
    source: source,
    theme: ‘ui-smoothness’,
    editmode: ‘selectedcell’,
    rowdetails: true,
    columnsreorder: true,
    groupable: true,
    rowsheight: 20,
    altrows: true,
    { text: ‘Group’, datafield: ‘GroupName’, width: 375 },
    { text: ‘Other Info ‘, datafield: ‘Miscellaneous1’, width: 350 },
    { text: ‘Culture’, datafield: ‘Culture’, width: 120 },
    { text: ‘Edit’, datafield: ‘Edit’, columntype: ‘button’, wdth: 70, cellsrenderer: function () {
    return “Edit”;
    editrow = row;
    $(“#popupWindow”).jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    $(“#GroupName”).val(dataRecord.GroupName);
    $(“#Miscellaneous1”).val(dataRecord.Miscellaneous1);
    $(“#Culture”).val(dataRecord.Culture);
    // show the popup window.
    $(“#popupWindow”).jqxWindow(‘open’);
    width: 480, resizable: false, theme: ‘ui-lightness’, isModal: true, autoOpen: false, cancelButton: $(“#Cancel”), modalOpacity: 0.01
    $(“#popupWindow”).on(‘open’, function () {
    $(“#firstName”).jqxInput(‘selectAll’);
    $(“#Cancel”).jqxButton({ theme: theme });
    $(“#Save”).jqxButton({ theme: theme });
    // update the edited row when the user clicks the ‘Save’ button.
    if (editrow >= 0) {
    var rowdata = { GroupName: $(“#GroupName”).val(), Miscellaneous1: $(“#Miscellaneous1”).val(), Culture: $(“#Culture”).val()
    alert($(“#GroupName”).val());
    alert($(“#Miscellaneous1”).val());
    alert($(“#Culture”).val());
    var rowid = $(‘#jqxgrid’).jqxGrid(‘getrowid’, editrow);
    $(‘#jqxgrid’).jqxGrid(‘updaterow’, rowid, rowdata);
    $(“#addrowbutton”).jqxButton();
    $(“#deleterowbutton”).jqxButton();
    $(“#updaterowbutton”).jqxButton();
    // update row.
    $(“#updaterowbutton”).bind(‘click’, function () {
    /*var datarow s generaterow(); */
    var selectedrowindex = $(“#jqxgrid”).jqxGrid(‘getselectedrowindex’);
    if (selectedrowindex >= 0 && selectedrowindex = 0 && selectedrowindex < rowscount) {
    var id = $("#jqxgrid").jqxGrid('getrowid', selectedrowindex);
    $("#jqxgrid").jqxGrid('deleterow', id);
    Edit
    Group:
    Other Info:
    Culture:
    Grid – Issue using popupedit #18864
    Keshavan
    here is the full code,
    var data = {};
    var row = {};
    return row;
    cache: false,
    dataType: ‘json’,
    data: rowdata,
    type: “POST”,
    commit(true);
    alert(errorThrown);
    commit(false);
    dataType: ‘json’,
    cache: false,
    type: “POST”,
    commit(true);
    commit(false);
    $.ajax(
    cache: false,
    dataType: ‘json’,
    data: rowdata,
    type: “POST”,
    alert(success);
    commit(true);
    alert(errorThrown);
    commit(false);
    var editrow = -1;
    width: 950,
    height: 350,
    source: source,
    rowdetails: true,
    groupable: true,
    rowsheight: 20,
    altrows: true,
    return “Edit”;
    editrow = row;
    if (editrow >= 0) {
    // update row.
    Edit
    Group:
    Other Info:
    Culture:
    Grid – Issue using popupedit #18865
    Keshavan
    I have pasted the display part of popup below, because of file size limit in editor, i could not paste the entire code.
    Keshavan
    Edit
    Group:
    Other Info:
    Culture:
    Grid – Issue using popupedit #18867
    Keshavan
    Finally, pasted the left out code.
    Keshavan
    Edit
    Group:
    Other Info:
    Culture:
    Grid – Issue using popupedit #18890
    Hello Keshavan,
    Please re-post your code and format it as explained in the forum topic Code Formatting.
    Grid – Issue using popupedit #18906
    Keshavan
    Hi Dimitar,
    I have pasted the code upon formatting accordingly,
    Keshavan
    <ht
    ml>
    <title id='Description'>In order to enter in edit mode, click any of the 'Edit' buttons.
    To save the changes, click the 'Save' button in the popup dialog. To cancel the
    changes click the 'Cancel' button in the popup dialog.</title>
    <link rel="stylesheet" href="/JqWidgets/jqwidgets/styles/jqx.base.css" type="text/css" />
    <link rel="stylesheet" href="/JqWidgets/jqwidgets/styles/jqx.ui-smoothness.css" type="text/css" />
    <link rel="stylesheet" href="/JqWidgets/jqwidgets/styles/jqx.ui-sunny.css" type="text/css" />
    <link rel="stylesheet" href="/Content/Site.css" type="text/css" />
    <script type="text/javascript" src="/JqWidgets/Scripts/gettheme.js"></script>
    <script type="text/javascript" src="/JqWidgets/Scripts/jquery-1.8.3.min.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqx-all.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.edit.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.sort.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.pager.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.filter.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.grouping.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.columnsresize.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.columnsreorder.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxwindow.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxlistbox.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxnumberinput.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxdropdownlist.js"></script>
    <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxinput.js"></script>
    var data = {};
    var row = {};
    row["GroupCompanyId"] = id;
    row["GroupName"] = " ";
    row["Miscellaneous1"] = " ";
    row["Culture"] = " ";
    return row;
    { name: 'GroupCompanyId' },
    { name: 'GroupName' },
    { name: 'Miscellaneous1' },
    { name: 'Culture' },
    url: 'GroupCompany/GetGroupCompanies',
    cache: false,
    dataType: 'json',
    url: 'GroupCompany/Add',
    data: rowdata,
    type: "POST",
    commit(true);
    alert(errorThrown);
    commit(false);
    // synchronize with the server - send delete command
    dataType: 'json',
    cache: false,
    url: '/GroupCompany/Delete/5',
    type: "POST",
    commit(true);
    commit(false);
    $.ajax(
    cache: false,
    dataType: 'json',
    url: 'GroupCompany/Update',
    data: rowdata,
    type: "POST",
    alert(success);
    commit(true);
    alert(errorThrown);
    commit(false);
    $("#GroupName").addClass('jqx-input');
    $("#Miscellaneous1").addClass('jqx-input');
    $("#Culture").addClass('jqx-input');
    $("#GroupName").width(375);
    $("#GroupName").height(23);
    $("#Miscellaneous1").width(375);
    $("#Miscellaneous1").height(23);
    $("#Culture").width(50);
    $("#Culture").height(23);
    if (theme.length > 0) {
    $("#GroupName").addClass('jqx-input-' + theme);
    $("#Miscellaneous1").addClass('jqx-input-' + theme);
    $("#Culture").addClass('jqx-input-' + theme);
    var editrow = -1;
    // initialize jqxGrid<a href="../../JqWidgets/index.htm">../../JqWidgets/index.htm</a>
    width: 950,
    height: 350,
    theme: 'ui-smoothness',
    selectionmode: 'singlecell',
    rowdetails: true,
    groupable: true,
    rowsheight: 20,
    altrows: true,
    { text: 'Group', datafield: 'GroupName', width: 400 },
    { text: 'Other Info ', datafield: 'Miscellaneous1', width: 400 },
    { text: 'Culture', datafield: 'Culture', width: 120 }
    $("#jqxgrid").bind('cellselect', function (event) {
    editrow = event.args.rowindex;
    alert("editrow " + editrow);
    var offset = $("#jqxgrid").offset();
    $("#popupWindow").jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    // get the clicked row's data and initialize the input fields.
    var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', editrow);
    alert(dataRecord.GroupName);
    alert(dataRecord.Miscellaneous1);
    alert(dataRecord.Culture);
    $("#GroupName").val(dataRecord.GroupName);
    $("#Miscellaneous1").val(dataRecord.Miscellaneous1);
    $("#Culture").val(dataRecord.Culture);
    $("#popupWindow").jqxWindow('show');
    $("#popupWindow").jqxWindow({ width: 480, resizable: false, theme: 'ui-sunny', isModal: true, autoOpen: false,
    cancelButton: $("#Cancel"), modalOpacity: 0.01
    $("#Cancel").jqxButton({ theme: theme });
    $("#Save").jqxButton({ theme: theme });
    // update the edited row when the user clicks the 'Save' button.
    $("#Save").click(function () {
    alert("Save " + editrow);
    if (editrow >= 0) {
    var row = { GroupName: $("#GroupName").val(), Miscellaneous1: $("#Miscellaneous1").val(), Culture: $("#Culture").val() }
    alert(row.GroupName);
    alert(row.Miscellaneous1);
    alert(row.Culture);
    var id = $("#jqxgrid").jqxGrid('getrowid', editrow);
    $('#jqxgrid').jqxGrid('updaterow', id, row);
    $("#popupWindow").jqxWindow('hide');
    $("#addrowbutton").jqxButton();
    $("#deleterowbutton").jqxButton();
    $("#updaterowbutton").jqxButton();
    // update row.
    $("#updaterowbutton").bind('click', function () {
    var selectedrowindex = $("#jqxgrid").jqxGrid('getselectedrowindex');
    $("#jqxgrid").jqxGrid('updaterow', id, datarow);
    // create new row.
    $("#addrowbutton").bind('click', function () {
    var datainformation = $("#jqxgrid").jqxGrid('getdatainformation');
    var rowscount = datainformation.rowscount;
    editrow = rowscount + 1;
    var datarow = generaterow(rowscount + 1);
    $("#jqxgrid").jqxGrid('addrow', rowscount + 1, generaterow(), 'top');
    //new code ends
    // delete row.
    $("#deleterowbutton").bind('click', function () {
    <div style="margin-left: 5px;">
    <div>
    <input id="addrowbutton" type="button" value=" (+) record" />
    <input id="deleterowbutton" type="button" style="margin-top: 10px;" value=" (-) record" />
    <input id="updaterowbutton" type="button" style="margin-top: 10px;" value=" Edit/Save" />
    <br />
    <div id='jqxWidget'>
    <div id="jqxgrid">
    <div style="margin-top: 30px;">
    <div id="cellbegineditevent">
    <div style="margin-top: 10px;" id="cellendeditevent">
    <div id="popupWindow">
    <div>
    Edit</div>
    <table>
    <tr>
    <td align="right">
    Group:
    </td>
    <td align="left">
    <input id="GroupName" />
    </td>
    </tr>
    <tr>
    <td align="right">
    Other Info:
    </td>
    <td align="left">
    <input id="Miscellaneous1" />
    </td>
    </tr>
    <tr>
    <td align="right">
    Culture:
    </td>
    <td align="left">
    <input id="Culture" />
    </td>
    </tr>
    <tr>
    <td align="right">
    </td>
    <td style="padding-top: 10px;" align="right">
    <input style="margin-right: 5px;" type="button" id="Save" value="Save" /><input id="Cancel"
    type="button" value="Cancel" />
    </td>
    </tr>
    </table>
    Grid – Issue using popupedit #18996
    Duplicate Post: http://www.jqwidgets.com/community/topic/grid-popupedit-update-issue. Please, avoid that in your future posts.
