jQuery UI Widgets › Forums › Grid › Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds
This topic contains 5 replies, has 2 voices, and was last updated by SSS 10 years, 7 months ago.
November 4, 2014 at 10:58 am Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds #62099
What I did is this ….
Create a Simple asp.net Web Page
Code –><%@ Page Language="C#" AutoEventWireup="true" CodeBehind="TestCellSelection.aspx.cs" Inherits="CourierApp.Project.TestCellSelection" %> <!DOCTYPE html> <html xmlns="http://www.w3.org/1999/xhtml"> <head runat="server"> <title id='Description'>This example shows how to create a Grid from JSON string.</title> <link rel="stylesheet" href="../JQWidgets/jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../JQWidgets/scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../JQWidgets/jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../JQWidgets/scripts/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { //GetData var data = {}; var dataFelds = {}; var dataCols = {}; GetDatas(); GetCol_Datafeilds(); GetCol_Columns(); function GetDatas() { $.ajax({ url: '<%=ResolveUrl("~/Project/Service.aspx/GridValues")%>', type: "POST", contentType: "application/json; charset=utf-8", dataType: "json", success: function (dataa) { var response = dataa.d; if (response != "Error") { data = response; console.log(data); } else { alert("Retrive Error !!"); } }, failure: function (data) { alert(response.d); }, error: function (error) { console.log("Error : " + error.responseText); } }); } function GetCol_Datafeilds() { $.ajax({ url: '<%=ResolveUrl("~/Project/Service.aspx/Col_Datafeilds")%>', type: "POST", contentType: "application/json; charset=utf-8", dataType: "json", success: function (dataa) { var response = dataa.d; if (response != "Error") { dataFelds = $.parseJSON(response); console.log(dataFelds); } else { alert("Retrive Error !!"); } }, failure: function (data) { alert(response.d); }, error: function (error) { console.log("Error : " + error.responseText); } }); } function GetCol_Columns() { $.ajax({ url: '<%=ResolveUrl("~/Project/Service.aspx/Col_Columns")%>', type: "POST", contentType: "application/json; charset=utf-8", dataType: "json", success: function (dataa) { var response = dataa.d; if (response != "Error") { dataCols = $.parseJSON(response); console.log(dataCols); } else { alert("Retrive Error !!"); } }, failure: function (data) { alert(response.d); }, error: function (error) { console.log("Error : " + error.responseText); } }); } // prepare the data var source = { datatype: "json", datafields: dataFelds, localdata: data }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid( { width: 1300, source: dataAdapter, columnsresize: true, columns: dataCols }); }); </script> </head> <body class='default'> <form id="form1" runat="server"> <div id='jqxWidget'> <div id="jqxgrid"> </div> </div> </form> </body> </html>
Next Create Three WebMethod For That….
Code —–>
using System; using System.Collections.Generic; using System.Linq; using System.Web; using System.Web.UI; using System.Web.UI.WebControls; using System.Web.Services; using System.Data; using System.Data.SqlClient; using System.Collections; using System.Web.Script.Serialization; using System.Web.Helpers; using BL; using DAL; using Newtonsoft.Json; public partial class Project_Service : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) { } [WebMethod] public static String GridValues() { String Qry = "SELECT top 10 [From Kgs] as From_Kg,[To kgs] as To_Kg,[1] as Zone1,[2] as Zone2,[3] as Zone3,[4] as Zone4,[5] as Zone5,[6] as Zone6,[7] as Zone7,[8] as Zone8,[9] as Zone9 FROM Tnt_Rate"; DataTable dt = DbAccess.FetchDatatable(Qry); System.Web.Script.Serialization.JavaScriptSerializer serializer = new System.Web.Script.Serialization.JavaScriptSerializer(); List<Dictionary<string, object>> rows = new List<Dictionary<string, object>>(); Dictionary<string, object> row; foreach (DataRow dr in dt.Rows) { row = new Dictionary<string, object>(); foreach (DataColumn col in dt.Columns) { row.Add(col.ColumnName, dr[col]); } rows.Add(row); } String Val = serializer.Serialize(rows); if (Val != "") { return (Val); } else { return "Error"; } } [WebMethod] public static String Col_Datafeilds() { String Qry = "SELECT top 10 [From Kgs] as From_Kg,[To kgs] as To_Kg,[1] as Zone1,[2] as Zone2,[3] as Zone3,[4] as Zone4,[5] as Zone5,[6] as Zone6,[7] as Zone7,[8] as Zone8,[9] as Zone9 FROM Tnt_Rate"; DataTable dt = DbAccess.FetchDatatable(Qry); System.Web.Script.Serialization.JavaScriptSerializer serializer = new System.Web.Script.Serialization.JavaScriptSerializer(); List<Dictionary<string, object>> rows = new List<Dictionary<string, object>>(); Dictionary<string, object> row = new Dictionary<string, object>(); String Col = ""; foreach (DataColumn col in dt.Columns) { row = new Dictionary<string, object>(); row.Add("name", col.ColumnName.ToUpper()); row.Add("type", "number"); rows.Add(row); } Col = serializer.Serialize(rows); //Col = JsonConvert.SerializeObject(rows); if (Col != "") { return (Col); } else { return "Error"; } } [WebMethod] public static String Col_Columns() { String Qry = "SELECT top 10 [From Kgs] as From_Kg,[To kgs] as To_Kg,[1] as Zone1,[2] as Zone2,[3] as Zone3,[4] as Zone4,[5] as Zone5,[6] as Zone6,[7] as Zone7,[8] as Zone8,[9] as Zone9 FROM Tnt_Rate"; DataTable dt = DbAccess.FetchDatatable(Qry); System.Web.Script.Serialization.JavaScriptSerializer serializer = new System.Web.Script.Serialization.JavaScriptSerializer(); List<Dictionary<string, object>> rows = new List<Dictionary<string, object>>(); Dictionary<string, object> row; String Col = ""; foreach (DataColumn col in dt.Columns) { row = new Dictionary<string, object>(); row.Add("text", col.ColumnName.ToUpper()); row.Add("datafield", col.ColumnName); row.Add("columntype", "textbox"); rows.Add(row); } Col = serializer.Serialize(rows); // Col = JsonConvert.SerializeObject(rows); if (Col != "") { return (Col); } else { return "Error"; } } }
Now the Data is not Populating in the Grid …..The Data comming is all Numeric Data …..Example :
[ {"From_Kg":0.001,"To_Kg":0.5,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":0.501,"To_Kg":1,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":1.001,"To_Kg":1.5,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":1.501,"To_Kg":2,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":2.001,"To_Kg":2.5,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":2.501,"To_Kg":3,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":3.001,"To_Kg":3.5,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":3.501,"To_Kg":4,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":4.001,"To_Kg":4.5,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988}, {"From_Kg":4.501,"To_Kg":5,"Zone1":3342,"Zone2":3520,"Zone3":3736,"Zone4":3779,"Zone5":4020,"Zone6":4502,"Zone7":4615,"Zone8":4809,"Zone9":4988} ]
Please help me to Populate the Grid !!!!
Please !!!November 4, 2014 at 11:01 am Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds #62100The Columns I Am generating is —>
[Object { text="FROM_KG", datafield="From_Kg", columntype="textbox"}, Object { text="TO_KG", datafield="To_Kg", columntype="textbox"}, Object { text="ZONE1", datafield="Zone1", columntype="textbox"}, Object { text="ZONE2", datafield="Zone2", columntype="textbox"}, Object { text="ZONE3", datafield="Zone3", columntype="textbox"}, Object { text="ZONE4", datafield="Zone4", columntype="textbox"}, Object { text="ZONE5", datafield="Zone5", columntype="textbox"}, Object { text="ZONE6", datafield="Zone6", columntype="textbox"}, Object { text="ZONE7", datafield="Zone7", columntype="textbox"}, Object { text="ZONE8", datafield="Zone8", columntype="textbox"}, Object { text="ZONE9", datafield="Zone9", columntype="textbox"}]
The Datafeild I am generating is —–>
[ Object { name="FROM_KG", type="number"}, Object { name="TO_KG", type="number"}, Object { name="ZONE1", type="number"}, Object { name="ZONE2", type="number"}, Object { name="ZONE3", type="number"}, Object { name="ZONE4", type="number"}, Object { name="ZONE5", type="number"}, Object { name="ZONE6", type="number"}, Object { name="ZONE7", type="number"}, Object { name="ZONE8", type="number"}, Object { name="ZONE9", type="number"} ]
November 4, 2014 at 11:19 am Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds #62103Hi SSS,
I think it should be without “Object”. It should be JSON in the format shown in our demos and documentation.
http://www.jqwidgets.comNovember 4, 2014 at 11:58 am Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds #62108I am receiving Data in JSON format …the format is —->
[{ “name”=”FROM_KG”, “type”=”number”},
{ “name”=”TO_KG”, “type”=”number”},
{ “name”=”ZONE1”, “type”=”number”},
{ “name”=”ZONE2”, “type”=”number”},
{ “name”=”ZONE3”, “type”=”number”},
{ “name”=”ZONE4”, “type”=”number”},
{ “name”=”ZONE5”, “type”=”number”},
{ “name”=”ZONE6”, “type”=”number”},
{ “name”=”ZONE7”, “type”=”number”}]which is not working….
How to Convert { “name”=”TO_KG”, “type”=”number”} format to
{ name=’TO_KG’, type=’number’} dynamically ….or plz help me to bind
dynamically …I mean I donot know the number of columns as well as row ….
How to achive that….pls suggest…
November 4, 2014 at 12:15 pm Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds #62110Hi SSS,
It should be valid JSON, i.e something like below:
` var source =
datatype: “xml”,
{ name: ‘ProductName’, type: ‘string’ },
{ name: ‘QuantityPerUnit’, type: ‘int’ },
{ name: ‘UnitPrice’, type: ‘float’ },
{ name: ‘UnitsInStock’, type: ‘float’ },
{ name: ‘Discontinued’, type: ‘bool’ }
root: “Products”,
record: “Product”,
url: url
};`Best Regards,
http://www.jqwidgets.comNovember 4, 2014 at 1:16 pm Grid Is not Populating with Dynamic JSON Data,Columns and Datafeilds #62112I have Successfully achieved ..what I wanted Thanks …… but the solution given is not to the point…..
Again Thanks …thanks for responding….
