jQuery UI Widgets Forums Dialogs and Notifications Window Grid Inside Window Bleeds Through
This topic contains 2 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 5 months ago.
  • Grid Inside Window Bleeds Through #46252
    drperk
    I have multiple windows on a tab and each window has a grid within it. When I move one window over the other the header of the window underneath bleeds to the top and stays on top. It does not matter which window I choose – the header of the window underneath always has it’s header bleed on top of the one being moved. The windows and grids are all built with different ID’s – they are always unique. None of the other elements on the window has the problem – only the grid header.
    I’ve tried bringing the window to the top after the move and the problem is still there.
    Any ideas?
    Grid Inside Window Bleeds Through #46253
    drperk
    I added the following after creating the windows and this solved the problem:
    $(‘div.jqx-grid-column-header’).css( “z-index”, 0 );
    Grid Inside Window Bleeds Through #46259
    Hi drperk,
    Could you provide a sample of that behavior with the latest version(jQWidgets 3.0.4)? I do not think that setting the ‘z-index’ is the best option.
