jQuery UI Widgets Forums Grid Grid grouping and group order.
This topic contains 4 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 7 months ago.
  • Grid grouping and group order. #30640
    wavetrex
    Hello again !
    I notice a change since versions before 3.0 related to grouping on grid.
    Before, the sorting order affected the order in which the groups are shown.
    First item in data -> became first group
    Second item in data, if part of the same group, it went to it
    Third item in data, if not part of the first group -> became the second group
    and so on.
    Now, it appears that the grid completely groups all rows and then attempts to show groups in a certain order which is completely ignoring the order of the data rows.
    (In most cases, it displays groups alphabetically sorted).
    My question is:
    Is there ANY way to control the order in which groups are shown ? Or create a custom sorting function ?
    I don’t necessarily want groups to be shown alphabetically.
    For example, if data in a column which the grid is grouped by contains:
    Priority: Urgent
    Priority: High
    Priority: Medium
    Priority: Low
    I want those groups to be shown in this order:
    Now instead it shows the groups alphabetically:
    High
    Low
    Medium
    Urgent
    I hope I made myself clear 😉
    Thanks !
    Grid grouping and group order. #30641
    wavetrex
    Some more information:
    – Groups are always sorted ascending, no matter what is chosen in the sorting row –
    For example, now I tried to group by a “date” field, which was sorted descending, with most recent date on top.
    When grouping, it shows the group with the oldest date first…
    Please remove the automatic group sorting, or give an option, thanks !
    Grid grouping and group order. #30644
    Hi wavetrex,
    By design, when paging is enabled, groups are Sorted. It is not possible to modify that default behavior through API settings.
    Grid grouping and group order. #30646
    wavetrex
    Well it wasn’t like that a few weeks ago… groups followed the data ordering.
    That date field example for example makes it very weird, and grouping numbers also has the same strange effect.
    Check this:
    http://img18.imageshack.us/img18/436/dxzm.jpg
    Shows the group on field “Flight Date”… with the down pointing arrow [V], the column is definitely sorted downwards
    -BUT-
    The dates appear ascending, because the groups are automatically sorted ascending.
    Definitely not an expected behavior…
    I hope that this “by design” gets changed back to the way it was, for groups order to follow the data order.
    Or even better, a way to choose group ordering from the API 😉
    Thanks !
    Grid grouping and group order. #30662
    Hi wavetrex,
    The Grouping works as it should in Paging mode and we do not plan any changes there or API extensions.
