jQuery UI Widgets Forums Grid Grid- Dropdownlist issue
This topic contains 4 replies, has 2 voices, and was last updated by  Keshavan 12 years, 2 months ago.
  • Grid- Dropdownlist issue #18426
    Keshavan
    I have a grid (with 2 column types as ‘dropdownlist’), the 2nd and 3rd column (after Id column) have col type ‘dropdownlist’,
    while all is ok, the 3rd column(2nd ‘dropdownlist’ col type ) doesn’t show Names and shows up only values.
    I interchanged the 2nd and 3rd column, the problem now swaps to the last dropdown col type in list.
    it’s identical code, i have the specific part of code below, is it focus problem ?? Please help.
    Keshavan
    var source3 =
    datafields:
    { name: ‘MemberEmployeeId’ },
    { name: ‘CompanyId’, value: ‘CompanyId’, values: { source: dataAdapater1.records, value: ‘CompanyId’, name: ‘CompanyName’} },
    { name: ‘DepartmentId’, value: ‘DepartmentId’, values: { source: dataAdapater2.records, value: ‘DepartmentId’,
    { name: ‘Employeecode’ },
    { name: ‘EmployeeName’ },
    { name: ‘MobileNo’ },
    { name: ‘EmailId’ },
    { name: ‘Active’ }
    url: ‘MemberEmployee/GetEmployees’,
    var dataAdapater3 = new $.jqx.dataAdapter(source3);
    $(“#jqxgrid”).jqxGrid
    width: 945,
    height: 350,
    source: dataAdapater3,
    theme: ‘ui-smoothness’,
    editable:true,
    selectionmode: ‘singlecell’,
    editmode: ‘click’,
    rowdetails: true,
    rowsheight: 20,
    columnsreorder: true,
    groupable: true,
    altrows: true,
    columns:
    { text: ‘Company’, datafield: ‘CompanyId’, columntype: ‘dropdownlist’,
    editor.jqxDropDownList({ displayMember: ‘CompanyName’, valueMember: ‘CompanyId’, source: dataAdapater1 })
    { text: ‘Department’, datafield: ‘DepartmentId’, columntype: ‘dropdownlist’,
    editor.jqxDropDownList({ displayMember: ‘DepartmentName’, valueMember: ‘DepartmentId’, source: dataAdapater2 })
    { text: ‘Code’, datafield: ‘EmployeeCode’, width: 60 },
    { text: ‘Name’, datafield: ‘EmployeeName’, width: 170 },
    { text: ‘Mobile No’, datafield: ‘MobileNo’, width: 110 },
    { text: ‘Email’, datafield: ‘EmailId’, width: 150 },
    { text: ‘If Active’, datafield: ‘Active’, width: 80 }
    Grid- Dropdownlist issue #18432
    Hi Keshavan,
    We are unable to run the provided code. Please, provide a complete sample which demonstrates your issue. In addition, provide details which version of jQWidgets you use.
    Grid- Dropdownlist issue #18436
    Keshavan
    Please find the complete code below,
    the version -jQWidgets v2.7.0 Release, Feb-08-2013
    Keshavan
    This example shows CRUD with Db
    // prepare data from external Company entity
    var source1 =
    datafields:
    { name: ‘CompanyId’ },
    { name: ‘CompanyName’ }
    url: ‘Company/GetPartCompanies’,
    async: false
    var dataAdapater1 = new $.jqx.dataAdapter(source1, { autoBind: true });
    // prepare data from external Department entity
    var source2 =
    datafields:
    { name: ‘DepartmentId’ },
    { name: ‘DepartmentName’ }
    url: ‘Department/GetPartDepartments’,
    async: false
    var dataAdapater2 = new $.jqx.dataAdapter(source2, { autoBind: true });
    var data = {};
    var depId = -1;
    var compId = 1;
    // source for main grid
    var generaterow = function (id) {
    var row = {};
    row[“MemberEmployeeId”] = id;
    row[“CompanyId”] = 1;
    row[“DepartmentId”] = 1;
    row[“EmployeeCode”] = ” “;
    row[“EmployeeName”] = ” “;
    row[“MobileNo”] = ” “;
    row[“EmailId”] = ” “;
    row[“Active”] = 1;
    return row;
    var source3 =
    datafields:
    { name: ‘Active’ }
    // synchronize with the server – send insert command
    cache: false,
    dataType: ‘json’,
    url: ‘MemberEmployee/Add’,
    data: rowdata,
    type: “POST”,
    commit(true);
    alert(“Commit done …… “);
    alert(rowdata.MemberEmployeeId);
    alert(rowdata.DepartmentId);
    alert(errorThrown);
    commit(false);
    // synchronize with the server – send delete command
    dataType: ‘json’,
    cache: false,
    url: ‘/MemberEmployee/Delete/5’,
    type: “POST”,
    // delete command is executed.
    commit(true);
    alert(jqXHR.statusText);
    commit(false);
    /* if (depId != undefined && depId != -1) {
    rowdata.Department = depId;
    depId = -1;
    /* if (compId != undefined && compId != -1) {
    rowdata.CompanyId = compId;
    compId = -1;
    $.ajax(
    cache: false,
    dataType: ‘json’,
    url: ‘MemberEmployee/Update’,
    data: rowdata,
    type: “POST”,
    alert(success);
    commit(true);
    alert(errorThrown);
    commit(false);
    width: 945,
    height: 350,
    editable:true,
    editmode: ‘click’,
    rowdetails: true,
    rowsheight: 20,
    groupable: true,
    altrows: true,
    columns:
    $(“#addrowbutton”).jqxButton();
    $(“#deleterowbutton”).jqxButton();
    $(“#updaterowbutton”).jqxButton();
    // update row.
    $(“#updaterowbutton”).bind(‘click’, function () {
    var selectedrowindex = $(“#jqxgrid”).jqxGrid(‘getselectedrowindex’);
    if (selectedrowindex >= 0 && selectedrowindex = 0 && selectedrowindex < rowscount) {
    var id = $("#jqxgrid").jqxGrid('getrowid', selectedrowindex);
    $("#jqxgrid").jqxGrid('deleterow', id);
    Grid- Dropdownlist issue #18478
    Below is a working sample with jQWidgets 2.8
    <title id='Description'>In this sample is illustrated how to create a Grid with column which displays values from foreign data source. The DropDownList editor associated to the column is populated from the foreign data source.</title>
    var theme = getDemoTheme();
    var countries = [
    { value: "AF", label: "Afghanistan" },
    { value: "AL", label: "Albania" },
    { value: "DZ", label: "Algeria" },
    { value: "AR", label: "Argentina" },
    { value: "AM", label: "Armenia" },
    { value: "AU", label: "Australia" },
    { value: "AT", label: "Austria" },
    { value: "AZ", label: "Azerbaijan" },
    { value: "BS", label: "Bahamas" },
    { value: "BH", label: "Bahrain" },
    { value: "BD", label: "Bangladesh" },
    { value: "BB", label: "Barbados" },
    { value: "BY", label: "Belarus" },
    { value: "BE", label: "Belgium" },
    { value: "BZ", label: "Belize" },
    { value: "BJ", label: "Benin" },
    { value: "BM", label: "Bermuda" },
    { value: "BR", label: "Brazil" },
    { value: "BN", label: "Brunei" },
    { value: "BG", label: "Bulgaria" },
    { value: "CM", label: "Cameroon" },
    { value: "CA", label: "Canada" },
    { value: "CL", label: "Chile" },
    { value: "CN", label: "China" },
    { value: "CO", label: "Columbia" },
    { value: "CR", label: "Costa Rica" },
    { value: "HR", label: "Croatia (Hrvatska)" },
    { value: "CU", label: "Cuba" },
    { value: "CY", label: "Cyprus" },
    { value: "CZ", label: "Czech Republic" },
    { value: "DK", label: "Denmark" },
    { value: "TP", label: "East Timor" },
    { value: "EC", label: "Ecuador" },
    { value: "EG", label: "Egypt" },
    { value: "ER", label: "Eritrea" },
    { value: "EE", label: "Estonia" },
    { value: "ET", label: "Ethiopia" },
    { value: "FI", label: "Finland" },
    { value: "FR", label: "France" },
    { value: "DE", label: "Germany" },
    { value: "GR", label: "Greece" },
    { value: "HK", label: "Hong Kong" },
    { value: "HU", label: "Hungary" },
    { value: "IS", label: "Iceland" },
    { value: "IN", label: "India" },
    { value: "ID", label: "Indonesia" },
    { value: "IR", label: "Iran" },
    { value: "IQ", label: "Iraq" },
    { value: "IE", label: "Ireland" },
    { value: "IL", label: "Israel" },
    { value: "IT", label: "Italy" },
    { value: "JM", label: "Jamaica" },
    { value: "JP", label: "Japan" },
    { value: "MX", label: "Mexico" },
    { value: "MC", label: "Monaco" },
    { value: "MA", label: "Morocco" },
    { value: "NL", label: "Netherlands" },
    { value: "NZ", label: "New Zealand" },
    { value: "NE", label: "Niger" },
    { value: "NG", label: "Nigeria" },
    { value: "KP", label: "North Korea" },
    { value: "NO", label: "Norway" },
    { value: "PA", label: "Panama" },
    { value: "PE", label: "Peru" },
    { value: "PH", label: "Philippines" },
    { value: "PL", label: "Poland" },
    { value: "PT", label: "Portugal" },
    { value: "RO", label: "Romania" },
    { value: "RU", label: "Russia" },
    { value: "SA", label: "Saudi Arabia" },
    { value: "SK", label: "Slovak Republic" },
    { value: "SI", label: "Slovenia" },
    { value: "ZA", label: "South Africa" },
    { value: "KR", label: "South Korea" },
    { value: "ES", label: "Spain" },
    { value: "SE", label: "Sweden" },
    { value: "CH", label: "Switzerland" },
    { value: "TN", label: "Tunisia" },
    { value: "TR", label: "Turkey" },
    { value: "UA", label: "Ukraine" },
    { value: "AE", label: "United Arab Emirates" },
    { value: "UK", label: "United Kingdom" },
    { value: "US", label: "United States" }
    var countriesSource =
    datatype: "array",
    { name: 'label', type: 'string' },
    { name: 'value', type: 'string' }
    localdata: countries
    var countriesAdapter = new $.jqx.dataAdapter(countriesSource, {
    autoBind: true
    var names = [
    { value: "1", label: "Name 1" },
    { value: "2", label: "Name 2" },
    { value: "3", label: "Name 3" },
    { value: "4", label: "Name 4" },
    { value: "5", label: "Name 5" },
    { value: "6", label: "Name 6" },
    { value: "7", label: "Name 7" },
    { value: "8", label: "Name 8" },
    { value: "9", label: "Name 9" }
    var namesSource =
    datatype: "array",
    localdata: names
    var namesAdapter = new $.jqx.dataAdapter(namesSource, {
    autoBind: true
    var gridSource =
    datatype: "array",
    localdata:
    { countryCode: "UK", nameId: "1" },
    { countryCode: "US", nameId: "2" },
    { countryCode: "DE", nameId: "3" },
    { countryCode: "FR", nameId: "4" },
    { countryCode: "IN", nameId: "5" },
    { countryCode: "HK", nameId: "6" }
    // name - determines the field's name.
    // value - the field's value in the data source.
    // values - specifies the field's values.
    // values.source - specifies the foreign source. The expected value is an array.
    // values.value - specifies the field's value in the foreign source.
    // values.name - specifies the field's name in the foreign source.
    // When the adapter is loaded, each record will have a field called "Country". The "Country" for each record comes from the countriesAdapter where the record's "countryCode" from gridAdapter matches to the "value" from countriesAdapter.
    { name: 'Country', value: 'countryCode', values: { source: countriesAdapter.records, value: 'value', name: 'label' } },
    { name: 'Name', value: 'nameId', values: { source: namesAdapter.records, value: 'value', name: 'label' } },
    { name: 'countryCode', type: 'string' },
    { name: 'nameId', type: 'string' }
    var gridAdapter = new $.jqx.dataAdapter(gridSource);
    width: 400,
    source: gridAdapter,
    selectionmode: 'singlecell',
    text: 'Country', width: 200, datafield: 'countryCode', displayfield: 'Country', columntype: 'dropdownlist',
    editor.jqxDropDownList({ source: countriesAdapter, displayMember: 'label', valueMember: 'value' });
    text: 'Name', datafield: 'nameId', displayfield: 'Name', columntype: 'dropdownlist',
    editor.jqxDropDownList({ source: namesAdapter, displayMember: 'label', valueMember: 'value' });
    <div id='jqxWidget'>
    <div id="jqxgrid">
    <div style="font-size: 13px; "margin-top: 20px; font-family: Verdana, Geneva, 'DejaVu Sans', sans-serif;" id="eventLog"></div>
    Grid- Dropdownlist issue #18487
    Keshavan
    I upgraded to latest version (2.8) and followed your sample code, Issue still persists .
    I have pasted my full code, request you to have a look in to pasted code .
    Keshavan
    var source1 =
    datafields:
    async: false
    var source2 =
    datafields:
    async: false
    var data = {};
    var depId = -1;
    var compId = 1;
    var row = {};
    row[“Active”] = 1;
    return row;
    var source3 =
    datafields:
    value: ‘DepartmentId’,name:’DepartmentName’ }},
    { name: ‘Active’ }
    cache: false,
    dataType: ‘json’,
    data: rowdata,
    type: “POST”,
    commit(true);
    alert(errorThrown);
    commit(false);
    dataType: ‘json’,
    cache: false,
    type: “POST”,
    commit(true);
    commit(false);
    depId = -1;
    compId = -1;
    $.ajax(
    cache: false,
    dataType: ‘json’,
    data: rowdata,
    type: “POST”,
    alert(success);
    commit(true);
    alert(errorThrown);
    commit(false);
    width: 945,
    height: 350,
    editable:true,
    editmode: ‘click’,
    rowdetails: true,
    rowsheight: 20,
    groupable: true,
    altrows: true,
    columns:
    { text: ‘Department’, datafield: ‘DepartmentId’, displayfield:’DepartmentName’, columntype: ‘dropdownlist’,
    // update row.
