jQuery UI Widgets Forums Grid Grid does not render when filterable
This topic contains 1 reply, has 1 voice, and was last updated by  Ivalde 10 years, 1 month ago.
  • Ivalde
    What can the reason be for this AngularJS based jqxGrid not rendering when filterable is included in the $scope.gridSettings?
    <?php
    <html ng-app=”demoApp”>
    <title id=”Description”>jqxGrid Binding to JSON using AngularJS</title>
    <link rel=”stylesheet” type=”text/css” href=”../../jqwidgets/styles/jqx.base.css” />
    <script type=”text/javascript” src=”../../jqwidgets/scripts/angular.min.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/scripts/jquery-1.11.1.min.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.filter.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.sort.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.columnsresize.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxangular.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/scripts/demos.js”></script>
    var demoApp = angular.module(“demoApp”, [“jqwidgets”]);
    demoApp.controller(“demoController”, function ($scope, $http) {
    $scope.createWidget = false;
    $http({
    method: ‘get’,
    url: ‘../../concrete/themes/elemental/domains/grid_data.php’
    }).success(function (data, status) {
    { name: ‘Code’},
    { name: ‘Name’}
    localdata: data
    $scope.gridSettings =
    width: 500,
    { text: ‘Code’, datafield: ‘Code’, width: 250 },
    { text: ‘Name’, datafield: ‘Name’, width: 250 }
    $scope.createWidget = true;
    }).error(function (data, status) {
    // Some error occurred
    <body>
    <div ng-controller=”demoController”>
    <jqx-grid jqx-create=”createWidget” jqx-settings=”gridSettings”></jqx-grid>
    Ivalde
    The problem was found to be missing references to jqxlistbox.js and jqxdropdownlist.js.
    Case closed.
