jQuery UI Widgets Forums Grid Grid-'Display' issue
This topic contains 1 reply, has 1 voice, and was last updated by  Keshavan 11 years, 4 months ago.
  • Grid-'Display' issue #48755
    Keshavan
    I have a grid with 1 column type ‘dropdownlist’.
    Issue is, when i populate the grid, the ‘displayname’ as defined in ‘dropdownlist’ column type showsup ONLY WHEN I CLICK
    ON THE said column.
    I have the relevant code below, please help.
    Keshavan
               var renderer = function (row, column, value) {
                    return '<span style="margin-left: 4px; margin-top: 5px; float: left;">' + value + '</span>';
              //  $("#jqxWidget").jqxDropDownList({ source: dropDownLS, displayMember: "CustomerName", valueMember: "CustomerId", width: 200, height: 25, theme: theme });
    <strong>            var source3 =
                    datafields:
                        { name: 'CustomerId' },
                        { name: 'CustomerName' }
                    url: '/Ship/GetCustomer',
                    async: false
                var dropDownLS = new $.jqx.dataAdapter(source3);</strong>
                                { name: 'OrderId' },
                                { name: 'OrderDate', type: 'date', format: 'MM/dd/yyyy' },
                                { name: 'OrderAmount' },
                                { name: 'OrderStatus' },
                            async: false,
                            url: url
                var orderAdapter = new $.jqx.dataAdapter(source);
                // create jqxgrid
                $("#jqxgrid").jqxGrid(
                    width: 920,
                    height: 370,
                    source: orderAdapter,
                    theme: 'ui-sunny',
                    editable:true,
                    rowdetails: true,
                    rowsheight: 25,
                    columnsreorder: true,
                    enabletooltips: true,
                    groupable: true,
                    rowdetailstemplate: { rowdetails: "<div id='grid' style='margin: 3px;'></div>", rowdetailsheight: 150, rowdetailshidden: true },
                    ready: function () {
                        $("#jqxgrid").jqxGrid('showrowdetails', -1);
                    columns:
                          { text: 'OrderId', datafield: 'OrderId', width: 100, editable: false, cellsrenderer: renderer },
                          <strong>{
                              text: 'Customer', datafield: 'CustomerId', displayfield: 'CustomerName', columntype: 'dropdownlist', width: 405,cellsrenderer: renderer,
                              createeditor: function (row, value, editor)
                                      urunId = $('#jqxgrid').jqxGrid('getcellvalue', row, "CustomerId");
                                      editor.jqxDropDownList
                                      ({ displayMember: 'CustomerName', valueMember:'CustomerId', source: dropDownLS, selectedIndex: urunId });
                          },</strong>
                          { text: 'cn', datafield: 'CustomerName', width: 100, editable: false, cellsrenderer: renderer },
                          { text: 'Order Date', datafield: 'OrderDate', formatString: 'MM/dd/yyyy', editable: false,theme: 'ui-sunny',width: 130, cellsrenderer: renderer },
                          { text: 'Order Amount', datafield: 'OrderAmount', width: 100, editable: false,cellsrenderer: renderer },
                          { text: 'Order Status', datafield: 'OrderStatus', width: 130, editable: false,cellsrenderer: renderer }
    Grid-'Display' issue #48756
    Keshavan
    I have sorted it out.
    Keshavan
