jQuery UI Widgets › Forums › Grid › Grid custom filter Key-value problem
This topic contains 2 replies, has 2 voices, and was last updated by Hristo 8 years, 10 months ago.
Hi, I am using asp net mvc and have this kind of problem. I have grid and this grid contains list of enum dropdownlist(Gender: Male=1, Female=2); I am filtering server side but with this column something is wrong;
var gendersource = { datatype: "json", datafields: [ { name: 'ID', type: 'number' }, { name: 'Name', type: 'string' } ], async: false, id: 'ID', url: '/Employees/GetGenders' }; var genderdataAdapter = new $.jqx.dataAdapter(gendersource); var source = { datatype: "json", datafields: [ { name: 'ID' }, { name: 'Firstname' }, { name: 'Lastname' }, { name: 'PersonalNO' }, { name: 'GenderName', type: 'string', value: 'Gender', values: { source: genderdataAdapter.records, value: 'ID', name: 'Name' } }, { name: 'BirthDate', type: 'date' }, { name: 'Gender', type: 'number' }, ], sort: function () { $("#jqxgrid").jqxGrid('updatebounddata', 'sort'); }, root: 'Rows', filter: function () { $("#jqxgrid").jqxGrid('updatebounddata', 'filter'); }, beforeprocessing: function (data) { source.totalrecords = data.TotalRows; }, sortcolumn: 'Firstname', sortdirection: 'asc', formatdata: function (data) { data.pagenum = data.pagenum || 0; data.pagesize = data.pagesize || 10; data.sortdatafield = data.sortdatafield || 'Firstname'; data.sortorder = data.sortorder || 'asc'; data.filterscount = data.filterscount || 0; formatedData = buildQueryString(data); return formatedData; }, url: '/Employees/list' }; var dataAdapter = new $.jqx.dataAdapter(source, { contentType: 'application/json; charset=utf-8', loadError: function (xhr, status, error) { alert(error); } }); $("#jqxgrid").jqxGrid({ width: '100%', source: dataAdapter, pageable: true, autoheight: true, showfilterrow: true, filterable: true, sortable: true, columns: [ { text: 'First name', dataField: 'Firstname', filtercondition: 'contains', width: '20%' }, { text: 'Last name', dataField: 'Lastname', filtercondition: 'contains', width: '20%' }, { text: 'Personal NO', dataField: 'PersonalNO', filtercondition: 'contains', width: '20%' }, { text: 'Gender', filtertype: 'list', width: '20%', filteritems: new $.jqx.dataAdapter(gendersource), dataField: 'Gender', displayfield: 'GenderName', createfilterwidget: function (column, htmlElement, editor) { editor.jqxDropDownList({ displayMember: "Name", valueMember: "ID" }); } }, { text: 'Birth Date', dataField: 'BirthDate', cellsformat: 'yyyy-MM-dd', filtertype: 'range', width: '20%' } ] });
in server side somehow filterValue0 is Male or Female Depending which one you choose and filterDataField0 is ‘GenderName’, but this is not correct I want to do tahe filterValue0 = 1 or 2 and filterDataField0 = ‘Gender’.
Dose anybody has problem like this?
Hello westbb,
Could you tell are there some errors messages in the console?
Also please check the received values are correct?Best Regards,
Hristo HristovjQWidgets team
