jQuery UI Widgets Forums Grid Grid columntype problem
This topic contains 4 replies, has 2 voices, and was last updated by  Franco01 9 years, 6 months ago.
  • Grid columntype problem #79104
    Franco01
    Hi!
    I use jQWidgets in my MVC 5 project, and in jqxgrid won’t appear columntype.
    I tried chechkbox, with bool column, and button.
    jQuery version is 1.11.1 like the Example.
    The datasource is Json.
                        dataType: "json",
                        dataFields: [
                            { name: 'Teljesnev', type: 'string' },
                            { name: 'Telefonszam', type: 'string' },
                            { name: 'SzerepkorNev', type: 'string' },
                            { name: 'Email', type: 'string' },
                            { name: 'SzuletesiDatum', type: 'date' },
                            { name: 'Aktiv', type: 'boolean' }
                        url: '/ProjektTag/ProjektTagLekerdezes/' + $("#Szerepkor").val() + '/' + $("#Teljesnev").val()
                    // create Tree Grid
                    //var editrow = -1;
                    $("#jqxgrid").jqxDataTable(
                        width: 920,
                        theme: 'darkblue',
                        //editable: true,
                        pageSize: 12,
                          { text: 'Teljesnév', columntype: 'textbox', dataField: 'Teljesnev', width: 160 },
                          { text: 'Telefonszám', dataField: 'Telefonszam', width: 120 },
                          { text: 'Szerepkör', dataField: 'SzerepkorNev', width: 120 },
                          { text: 'Email', dataField: 'Email', width: 220 },
                          { text: 'Születési dátum', dataField: 'SzuletesiDatum', width: 140, cellsformat: 'yyyy.MM.dd' },
                          { text: 'Aktiv', dataField: 'Aktiv', columntype: 'checkbox' },
                              text: 'Edit', datafield: 'Edit', columntype: 'button', cellsrenderer: function () {
                                  return "Edit";
                                  editrow = row;
                                  var offset = $("#jqxgrid").offset();
                                  $("#popupWindow").jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60 } });
                                  // get the clicked row's data and initialize the input fields.
                                  var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', editrow);
                                  $("#Teljesnev").val(dataRecord.Teljesnev);
                                  $("#Telefonszam").val(dataRecord.Telefonszam);
                                  $("#SzerepkorNev").val(dataRecord.SzerepkorNev);
                                  $("#Email").val(dataRecord.Email);
                                  $("#SzuletesiDatum").val(dataRecord.SzuletesiDatum);
                                  // show the popup window.
                                  $("#popupWindow").jqxWindow('open');
    In the grid I can see onlye true/false in the bool column, and edit label instead of button.
    Grid columntype problem #79107
    ivailo
    Hi Franco01,
    Instead type: 'boolean' use type: ‘bool’.
    Also in you are not using jqx-all.js please check the references to jqxbuttons.js and jqxcheckbox.js
    Ivailo Ivanov
    Grid columntype problem #79111
    Franco01
    Thanks.
    The first i was tried type: ‘bool’, and it does not work, so i tried boolean.
    And I use jqxbuttons.js and jqxcheckbox.js in the reference.
    Grid columntype problem #79112
    ivailo
    Hi Franco01,
    Your code is similar to our popup editing demo so here is an example with localdata.
    Please check one more time the steps about integration of MVC5 with jQWidgets.
    If you are not with the latest version, please try to update.
    Also you can check the console for errors.
    Ivailo Ivanov
    Grid columntype problem #79113
    Franco01
    Thank you your answer.
    I checked it, and I don’t find the difference between the 2 codes.
    Everything is fine only the columntype attribute doesn’t work..
