jQuery UI Widgets Forums Grid Grid Cell population using key value and drop down
This topic contains 2 replies, has 2 voices, and was last updated by  NIKHILAR 8 years, 2 months ago.
  • NIKHILAR
    Hi
    I have created dropdownlist in a grid cell. When selecting items in drop down using custom editor, nothing is getting printed in the cell.
    Checked many examples but still not able to make it work. Can you please provide some help . Below is the code
    var data = [{“productname”:”Cold Drink”, “productid”:”1″},{“productname”:”Coffee”,”productid”:”2″}];
    var products =
    localdata: data,
    datatype: “array”,
    // and with parameter false if the synchronization failder.
    commit(true);
    datafields:
    { name: ‘productid’, type: ‘string’ }
    var pdtAdapter = new $.jqx.dataAdapter(products, {
    autoBind: true});
    localdata: data,
    datatype: “array”,
    commit(true);
    datafields:
    { name: ‘mode’, type: ‘string’ },
    { name: ‘strSubModes’, value: ‘mode’, values: {source: pdtAdapter.records, value: ‘productid’, name: ‘productname’ } }
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid(
    width: 850,
    selectionmode: ‘singlecell’,
    text: ‘Products’, columntype: ‘dropdownlist’, datafield: ‘mode’, displayfield:’strSubModes’,
    createeditor: function (row, cellvalue, editor, cellText, width, height) {
    // construct the editor.
    editor.jqxDropDownList({
    checkboxes: true, source: pdtAdapter, displayMember: ‘productname’, valueMember: ‘productid’, width: width, height: height,
    selectionRenderer: function () {
    return “<span style=’top:4px; position: relative;’>Please Choose:</span>”;
    },cellvaluechanging: function (row, column, columntype, oldvalue, newvalue) {
    // return the old value, if the new value is empty.
    alert(newvalue + ‘ old ‘ +oldvalue);
    initeditor: function (row, cellvalue, editor, celltext, pressedkey) {
    // set the editor’s current value. The callback is called each time the editor is displayed.
    var items = editor.jqxDropDownList(‘getItems’);
    editor.jqxDropDownList(‘uncheckAll’);
    if(null!=cellvalue){
    var values = cellvalue.split(/,\s*/);
    for (var j = 0; j < values.length; j++) {
    for (var i = 0; i < items.length; i++) {
    if (items[i].value === values[j]) {
    editor.jqxDropDownList(‘checkIndex’, i);
    editor.jqxDropDownList(‘selectedIndex’, i);
    geteditorvalue: function (row, cellvalue, editor) {
    // return the editor’s value.
    return editor.val();
    I think the return object should be something like: {label: …., value: … } as it is key/value column i.e editor.val() will not be enough as it returns only the value as Text where object is expected.
    NIKHILAR
    HI Peter
    I tried it using below command
    return {label: returnLabel, value:returnValue}; // where label and value is calculated by looping into selected items. returnLabel is concatenation of list names i.e. product names and returnValue is concatenation of list values i.e. product ids
    Now the problem is that label is getting displayed but when opening the drop down again – selected items are not getting auto selected because the cell value is coming as product names .
    How to overcome this ?
    I would also want my product ids to be stored in cell value but display the product names
