jQuery UI Widgets Forums Grid Grid and JQWindow Issue
This topic contains 2 replies, has 2 voices, and was last updated by  raybtwo 2 years, 11 months ago.
  • Grid and JQWindow Issue #121954
    raybtwo
    A little bit of background before I jump into the issue I am having. I am in the process of updating a web application that went into use back in 2014. Mainly I am focused on updating the various code libraries that the application uses such as JQWidgets and JQuery to their most recent versions. Note also that I am not the original developer of the app.
    I have updated JQWidgets from version 3.4.0 to version 14.
    The only issue I have run into at this point is with a grid. I have a grid with an edit button that when clicked pops up a window so that comments can be added to the entry. After updating to version 14 when I click on the edit button the grid completely locks up and is unresponsive until the browser is refreshed.
    There are no errors in the Chrome developers console. Any ideas what might be causing this?
    Here is the code:
    $("#jqxgrid").jqxGrid({
        width:1220,
        virtualmode: true,
        theme: 'material',
        pagermode: 'simple',
        rendergridrows: function (params) {
          return params.data;
        showtoolbar: true,
          var me = this;
          var container = $("<div style='margin: 5px;'></div>");
          var span = $("<span style='float: left; margin-top: 5px; margin-right: 4px; height: 100px;'>Clear Filters: </span>");
          var input = $("<input id='btnClearAll' type='button' value='Clear' style='height: 30px important!;' />");
          toolbar.append(container);
          container.append(span);
          container.append(input);
          input.on('click', function (event) {
            var filterinfo = $("#jqxgrid").jqxGrid('getfilterinformation');
            if(parseInt(filterinfo.length) > 0) {
            	$("#jqxgrid").jqxGrid('clearfilters');
        pagesize: 20,
        rowdetails: true,
        rowdetailstemplate: {
          rowdetails: "<div style='margin: 10px;'><ul style='margin-left: 30px;'><li class='title'></li><li>Description</li><li>Attachments</li><li>Comments</li></ul><div class='information'></div><div class='description'></div><div class='attachments'></div><div class='comments'></div></div>",
          rowdetailsheight:200
        initrowdetails: initRowDetails,
        showfilterrow: true,
        autoshowfiltericon: true,
        showfiltermenuitems: true,
        enabletooltips: true,
        autoshowloadelement: false,
            text: 'Name', cellclassname: hasAttachClass, datafield: 'fullName', width: 140, editable: true,
            validation: function(cell, value) {
              var str = $.trim(value);
              var regex = /^[a-zA-Z ]+$/g;
              return regex.test(str);
            text: 'Phone', cellclassname: hasAttachClass, datafield: 'phone', width: 120, editable: true,
              var regex = /^[1-9][0-9]{2}[\-]?[1-9][0-9]{2}[\-]?[0-9]{4}$/g
            text: 'User Type', cellclassname: hasAttachClass, columntype: 'dropdownlist', datafield: 'userTypeId', displayfield: 'userType', filteritems: userTypeFilterList, width: 120,
              editor.jqxDropDownList({ source: userTypeDropDown, displayMember: 'name', valueMember: 'id' });
            }, filtertype: 'checkedlist', editable: true
            text: 'ISU Unit', cellclassname: hasAttachClass, columntype: 'dropdownlist', datafield: 'isuUnitId', displayfield: 'isuUnit', filteritems: isuUnitFilterList, width: 210,
              editor.jqxDropDownList({ source: isuUnitDropDown, displayMember: 'name', valueMember: 'id' });
        text: 'Analyst', cellclassname: hasAttachClass, columntype: 'dropdownlist', datafield: 'analystId', displayfield: 'analyst', filteritems: analystFilterList, filtertype: 'checkedlist', width: 120,
              editor.jqxDropDownList({ source: analystDropDown, displayMember: 'shortName', valueMember: 'id' });
            }, editable: true
            text: 'Date Added', cellclassname: hasAttachClass, datafield: 'requestAdded', cellsformat: dateFormat, width: 120, columntype: 'datetimeinput', filtertype: 'date', editable: true,
              return true;
            text: 'Date Needed', cellclassname: hasAttachClass, datafield: 'requestDate', cellsformat: dateFormat, width: 120, columntype: 'datetimeinput', filtertype: 'date', editable: true,
              var data = $('#jqxgrid').jqxGrid('getrowdata', cell.row);
              var reqDate = new Date(data.requestAdded);  //The DateAdded of the row in the database
              var needDate = new Date(value);
              reqDate.setHours(0, 0, 0 ,0);
              needDate.setHours(0, 0, 0 ,0);
              //if(reqDate > needDate) { return false; }
              return true;
            text: 'Closed Date', cellclassname: hasAttachClass, columntype: 'datetimeinput', datafield: 'closedDate', cellsformat: dateFormat, width: 120, filtertype: 'date', editable: true,
              if(value == "") { return true; }
              var cloDate = new Date(value);
              cloDate.setHours(0, 0, 0 ,0);
              //if(reqDate > cloDate) { return false; }
              return true;
          { text: 'Closed', cellclassname: hasAttachClass, columntype: 'checkbox', datafield: 'isClosed', width: 70, filtertype: 'boolean', filteritems: ['Open', 'Close'], editable: true },
    	  { text: 'Edit', columntype: 'button',cellsrenderer: function () { return "Edit";},filterable:false,
    	           buttonclick: function (row) {
                         editrow = row;
                         var offset = $("#jqxgrid").offset();
                         $("#popupWindow").jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60 } });
                         // get the clicked row's data and initialize the input fields.
                         var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', editrow);
                         $("#txtComments").val(dataRecord.comments);
                         // show the popup window.
                         $("#popupWindow").jqxWindow('open');
    		width: 1250, resizable: false,  isModal: true, autoOpen: false, cancelButton: $("#Cancel"), modalOpacity: 0.01
    	$("#popupWindow").on('open', function () {
    	// update the edited row when the user clicks the 'Save' button.
    	$("#Save").click(function () {
    		if (editrow >= 0) {
    		   var data = $('#jqxgrid').jqxGrid('getrowdata', editrow);
    		   data.comments = $("#txtComments").val();
    		   var rowID = data.id;
                //alert(rowID);
    			 $.post("/datarequest/index.cfm?event=admin.update", {
    			 COLUMN: 'comments',
    			 VAL: data.comments
    			 }).done(function () {
    					$("#jqxgrid").jqxGrid('updatebounddata');   //Refresh Data
    				}).fail(function() {  });
    			$("#popupWindow").jqxWindow('hide');
      var oVal;	//Original value
      var nVal;	//New column value
      var isDropDown = false;
      // events
      $("#jqxgrid").on('cellbeginedit', function (event) {
        var args = event.args;
        isDropDown = false;
        if(args.columntype === 'dropdownlist') {
          isDropDown = true;
        oVal = args.value;
      //Cell Edit Ends
          nVal = args.value.value;
        else {
          nVal = args.value;
      //Cell edit end  save
      $("#jqxgrid").on('cellvaluechanged', function (event) {
        var data = $('#jqxgrid').jqxGrid('getrowdata', args.rowindex);
        var reqId = data.id;	//The id of the row in the database
        var dataField = args.datafield;
       if(!isDropDown) {
          nVal = args.value;
       //if(!nVal) { return; }
       if(oVal === nVal) { return; }
        COLUMN: dataField,
        VAL: nVal
      $("#jqxgrid").on("filter", function (event) {
      $("#jqxgrid").on("sort", function (event) {
    Grid and JQWindow Issue #121959
    Can you please give me a demo? Meanwhile, have a look at the example with a popup editing:
    https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/popupediting.htm
    The best option would be to give me a demo (host it if needed)
    Svetoslav Borislavov
    Grid and JQWindow Issue #121961
    raybtwo
    Thanks for the response Svetoslav. Let me see if I can come up with a demo for you. Right now the web app is behind the a firewall. Let me see if I can get it running on a public facing web server.
