jQuery UI Widgets Forums Lists DropDownList getItemByValue Issue
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 6 months ago.
  • getItemByValue Issue #12154
    marchip
    Hi
    i have a drop down list. I add two item.
    var currentSeriesString =”A|B”;
    var source = currentSeriesString.split(‘|’);
    $(“#series”).jqxDropDownList({ source: source, checkboxes: true, width: 200, height: 25, theme: ‘classic’ });
    When i Call
    var item = $(“#series”).jqxDropDownList(‘getItemByValue’, “B”);
    item is undefined. Why?
    getItemByValue Issue #12156
    Hi marchip,
    getItemByValue works for items with label and value when the displayMember and valueMember properties are specified. The source in your sample is a simple array and there is no value there.
    getItemByValue Issue #12165
    marchip
    var source = new Array();
    var arr = currentSeriesString.split(‘|’);
    for (i = 0; i < arr.length; i++) {
    var itm = {};
    itm["name"] = arr[i];
    source.push(itm);
    $("#series").jqxDropDownList({ source: source, displayMember: 'name', valueMember: 'name', checkboxes: true, width: 200, height: 25, theme: 'classic' });
    Not function.
    getItemByValue Issue #12168
    Hi marchip,
    Below is a working code:
                    var currentSeriesString ="A|B";
    var arr = currentSeriesString.split('|');
    var itm = {};
    source.push(itm);
    var dataObj = { localdata: source };
    var dataAdapter = new $.jqx.dataAdapter(dataObj);
    $("#series").jqxDropDownList({ source: dataAdapter, displayMember: 'name', valueMember: 'name', width: 200, height: 25, theme: 'classic' });
    var item = $("#series").jqxDropDownList('getItemByValue', 'B');
