jQuery UI Widgets Forums Grid Get Group Index From Selected Row
This topic contains 1 reply, has 2 voices, and was last updated by  svetoslav_borislavov 3 years, 1 month ago.
  • Get Group Index From Selected Row #121877
    matthew.greenwood
    Is it possible to get the group index of a selected row? I know from other posts that adding or deleting a row causes the groups to collapse, as the grid gets re-rendered. Therefore I was hoping to be able to get the group index of the row to be deleted and then once it has been deleted use that index id to re-expand the correct group.
    Get Group Index From Selected Row #121882
    Hi Matthew,
    Here is an example of getting the group`s index:
    $(‘#jqxgrid’).on(‘rowselect’, function (event) {
    var args = event.args;
    const index = getIndexOfGroupBySelectedRow(args);
    //Assign the index to a variable
    function getIndexOfGroupBySelectedRow(rowArgs) {
    console.log(row);
    const groupsCount = $(‘#jqxgrid’).jqxGrid(‘getrootgroupscount’);
    let groupIndex = -1;
    for (let i = 0; i < groupsCount; i++) {
    const currentGroupName = $(‘#jqxgrid’).jqxGrid(‘getgroup’, i).group;
    const rowData = rowArgs.row;
    for (const key in rowData) {
    groupIndex = i;
    Please feel free to contact me if you need any further information!
    Svetoslav Borislavov
    https://www.jqwidgets.com
