jQuery UI Widgets › Forums › Grid › Get Group Index
This topic contains 6 replies, has 3 voices, and was last updated by revilo7 10 years, 2 months ago.
AuthorGet Group Index Posts
I am trying to expand/collapse a group when the group header row is clicked with the ‘expandgroup’ and ‘collapsegroup’ methods. Both of these methods accept the groups index (integer) and I cannot figure out a way to get this value. I know that the click event args contains the name of the group, but not the index.
Is there anyway to retrieve the groups index?
It seems that there are multiple methods that require this argument, yet there are no ways of getting it. Must it be arbitrarily supplied?
Thanks is advance!
Hi aoverton07,
Groups Index starts from 0.The first group’s index is 0, the second one is 1 and so on.
If you know the group’s Name, you can easily learn its index.
Example:
// trigger expand and collapse events. $("#jqxgrid").on('groupexpand', function (event) { var args = event.args; $("#expandedgroup").text("Group: " + args.group + ", Level: " + args.level); var rows = $("#jqxgrid").jqxGrid('getdisplayrows'); var groupIndex = -1; for (var i = 0; i < rows.length; i++) { if (rows[i].level === args.level) { groupIndex++; if (args.group == rows[i].group) { break; } } } alert(groupIndex); });
http://www.jqwidgets.com/I am trying to feed the groups index to the ‘expandgroup’ and ‘collapsegroup’ methods so it does not make sense to get the groups index from the ‘groupexpand’ event, I need to the index so that I know WHICH group to expand. Is there any other way to get the groups index (level) besides the ‘groupexpand’ and ‘groupcollapse’ event handlers?
Hi aoverton07,
The first group’s Index is 0, the second group’s Index is 1 and so on. Through API, you can expand or collapse Root groups.
http://www.jqwidgets.com/Peter,
Could you provide a solution where a group is expanded when the Group Details Row is double clicked?
Alex Overton
Hi Alex,
The feature you’re looking for is not available.
http://www.jqwidgets.com/Hello!
I was trying somethin similar. My objective was to expand/collapse a group when its group row is clicked. Here’s how I accomplished it.if (event.args.rowindex == -1 && event.args.row.group != undefined) {
var iter = true;
var groupIndex = 0;
while (iter) {
if ($(‘#jqxGrid’).jqxGrid(‘getgroup’, groupIndex).group == event.args.row.group) {
iter = false;
break;
groupIndex += 1;
$(‘#jqxGrid’).jqxGrid($(‘#jqxGrid’).jqxGrid(‘getgroup’, groupIndex).expanded ? ‘collapsegroup’ : ‘expandgroup’, groupIndex);
return;
