jQuery UI Widgets Forums Grid Get filter element from specific column
This topic contains 3 replies, has 3 voices, and was last updated by  mr_kirkwood 2 years, 3 months ago.
  • Get filter element from specific column #103211
    areisyus
    I’m using angular 7 and I need to get filter input from a specific column on filter callback function to organize filter data but couldn’t find a way to do it.
    Any ideas on how could I retrieve filter element from a specific column?
    I can’t use getfilterinformation function, once I call it filter seems to stop calling filter callback function I didn’t find the reason but seems lime grid crushes somehow, without throws any exception.
    Get filter element from specific column #103221
    Martin
    Hello areisyus,
    Can you, please, check the following Example.
    You retrieve the value of the filter input inside the onFilter event handler.
    Martin
    Get filter element from specific column #132588
    mr_kirkwood
    I can get the onFilter to work. I would like to be able to grab other data from the onFilter results.
    https://www.flickr.com/photos/mr_kirkwood/52690885929/in/dateposted-public/
    I would like to be able to get the building ID as well. The above code gives me only the filter from the dropdown select field (Building Name). Is there anyway to get this data?
    Get filter element from specific column #132590
    mr_kirkwood
    I figured out a way around. I get the Filter data, then I passed it into another query to match the name to get the ID I was looking for.
    ` $ (‘#roomsSortTable’).on (‘filter’, function (event)
    let filters = event.args.filters;
    if (filters.length > 0) {
    console.log (filters[filters.length – 1].filter.getfilters ()[0].value);
    tableFilterDataText = filters[filters.length – 1].filter.getfilters ()[0].value
    console.log (tableFilterDataText)
    getBuldingNameText = tableFilterDataText;
    console.log (getBuldingNameText);
    improvementTableData.filter (c => c.LONGNAME === getBuldingNameText).forEach (function (d)
    console.log (d);
    console.log (d.BUILDINGID);
    getBuildingIDText = d.BUILDINGID;
    } else {
    console.log (“undefined”)
    Thanks!
