jQuery UI Widgets Forums General Discussions General How To
This topic contains 3 replies, has 2 voices, and was last updated by  Martin 6 years, 7 months ago.
  • General How To #102340
    dishmann
    Hey all,
    Not sure where I could have put this topically.
    2 Questions.
    1. Is there a “label” widget ? (Not the same as the caption for an input. But similar in that it is a “caption” without the associated input)
    2. If there is not a label widget. Is there a way for me to have an HTML Element participate in any “theme” associated with the widget collection?
    I can code OK but speaking in human terms is a challenge for me.
    I hope I communicated OK
    General How To #102352
    Martin
    Hello dishmann,
    Can you clarify what do you mean by caption? For what purpose do you need it?
    It would be easier if you show an example.
    Themes could not be applied to other elements that are not from jQWidgets.
    Martin
    General How To #102357
    dishmann
    Thanks Martin.
    I believed that if I applied the appropriate jqx CSS classes to a simple HTML Element I could make it work.
    Nice to know that cant be done.
    General How To #102364
    Martin
    Hello dishmann,
    Yes, you can inspect the classes and apply the appropriate ones on HTML Elements.
    Here is an Example with a simple </label> and jqxInput both with ‘material’ theme.
    Martin
