jQuery UI Widgets Forums Editors NumberInput Focus on load
This topic contains 2 replies, has 3 voices, and was last updated by  Murthy 12 years, 4 months ago.
  • Focus on load #9647
    myamoe
    How can I set the numberInput box to be the “focus” on page Load? Normally I use a js function and use the id of the form input and set it to focus, but that doesn’t seem to work with the widget.
    Focus on load #9657
    Hi myamoe,
    Unfortunately, setting the focus of an input field is not currently supported. I’ll create a work item about adding a ‘focus’ method to the widget.
    Best Wishes,
    Focus on load #14716
    Murthy
    Hi myamoe,
    you can also do it like this..
    $(“#numperinput”).find(‘input’).focus();
