jQuery UI Widgets Forums Navigation Menu, Context Menu First element triggered on Menu
This topic contains 1 reply, has 2 voices, and was last updated by  Nadezhda 10 years, 2 months ago.
  • First element triggered on Menu #68171
    agrgal
    Hi mates,
    I haven’t found a proper answer to my problem on internet, so I’m now asking here. Excuse my poor English! 🙂
    I have a jqxMenu working! But I’d like to trigger first element click event when the webpage is first loaded… (div “menuGrupos”).
    See my code:
    		$("#menuGrupos").jqxMenu({ mode: 'horizontal' , theme:'ui-sunny'});
    		$("#menuGrupos").css('visibility', 'visible');
    		$('#menuGrupos').on('itemclick', function (event) {
    				event.preventDefault;
    				// var element = event.args;
    				// alert($(event.target).attr("class")); alert($(event.target).attr("id"));
    				opcionMenu = $(event.target).attr("id");
    				$("#zonaItems").hide();
    		  	    eligeGrupoItems(); // función que oculta los items menos los escogidos
    				$("#zonaItems").fadeIn("slow");
    				// $("#testear").html("Opcion Menu "+$("#menuGrupos li a:first").attr("id"));
    I tried things like…
    $("#menuGrupos li a:first").trigger("click");
    $("#menuGrupos").jqxMenu('openItem', "ACTITUD"); // ACTITUD is the first id attr.
    But none of them worked!
    HTML:
    	echo '<div id="menuGrupos" style="visibility: hidden;"><ul>';
    							foreach ($opiniones->listadoDeGrupos["grupo"] as $clave => $valor) {
    								echo '<li id="'.$valor.'"><img style="margin-right: 15px; width:15px;" src="imagenes/iconos/item.png"><a id="'.$valor.'" class="grupos">'.$valor.'</a></li>';
    						echo '</ul></div>';
    First element triggered on Menu #68250
    Nadezhda
    Hello agrgal,
    Here is an example which shows how to trigger click event of the first menu item when the webpage is loaded. If you don’t know the id selector of the first item you can use $("#jqxWidget li:first").trigger("click"); instead $("#12").trigger("click");.
        <title></title>
    <body>
        <div id='content'>
                    var data = [
                        "id": "12",
                        "text": "Frappuccino",
                        "parentid": "-1",
                        "subMenuWidth": '250px'
                        "text": "Chocolate Beverage",
                        "id": "1",
                        "parentid": "-1",
                        "id": "2",
                        "parentid": "1",
                        "text": "Hot Chocolate"
                        "id": "3",
                        "parentid": "1",
                        "text": "Peppermint Hot Chocolate"
                        "id": "4",
                        "parentid": "1",
                        "text": "Salted Caramel Hot Chocolate"
                        "id": "5",
                        "parentid": "1",
                        "text": "White Hot Chocolate"
                        "id": "6",
                        "text": "Espresso Beverage",
                        "parentid": "-1",
                        "subMenuWidth": '200px'
                        "id": "7",
                        "parentid": "6",
                        "text": "Caffe Americano"
                        "id": "8",
                        "text": "Caffe Latte",
                        "parentid": "6"
                        "id": "9",
                        "text": "Caffe Mocha",
                        "parentid": "6"
                        "id": "10",
                        "text": "Cappuccino",
                        "parentid": "6"
                        "id": "11",
                        "text": "Pumpkin Spice Latte",
                        "parentid": "6"
                        "id": "13",
                        "text": "Caffe Vanilla Frappuccino",
                        "parentid": "12"
                        "id": "15",
                        "text": "450 calories",
                        "parentid": "13"
                        "id": "16",
                        "text": "16g fat",
                        "parentid": "13"
                        "id": "17",
                        "text": "13g protein",
                        "parentid": "13"
                        "id": "14",
                        "text": "Caffe Vanilla Frappuccino Light",
                        "parentid": "12"
                            { name: 'id' },
                            { name: 'parentid' },
                            { name: 'text' },
                            { name: 'subMenuWidth' }
                        localdata: data
                    // create data adapter.
                    // perform Data Binding.
                    dataAdapter.dataBind();
                    // get the menu items. The first parameter is the item's id. The second parameter is the parent item's id. The 'items' parameter represents
                    // the sub items collection name. Each jqxTree item has a 'label' property, but in the JSON data, we have a 'text' field. The last parameter
                    // specifies the mapping between the 'text' and 'label' fields.
                    var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'text', map: 'label' }]);
                    $('#jqxWidget').jqxMenu({ source: records, height: 30, width: '400px' });
                    $("#jqxWidget").on('itemclick', function (event) {
                        if (event.args.id == "12") {
                            alert("1st item is clicked");
            <div id='jqxWidget'>
    Nadezhda
