jQuery UI Widgets Forums Grid filter starts_with works with one column but not the other
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 4 months ago.
  • paries
    I am creating a grid with
    showfilterrow: true,
    I have three columns
    When i start typing in the name field it filters fine.
    If I type a 1 in the id datafield, the entire list selects, if i type in 12 i would expect the list to clear(because there are no ids that start with 12), but it does nothing.
    score behaves the same. Only Name works as expected.
    Any help would be appreciated
    id, name and score
    { text: ‘Id’, datafield: ‘id’, filtertype: ‘textbox’, filtercondition: ‘starts_with’, width: 100 },
    { text: ‘Name’, datafield: ‘name’, filtertype: ‘textbox’, filtercondition: ‘starts_with’, width: 200 },
    { text: ‘Score’, datafield: ‘score’, filtertype: ‘textbox’, filtercondition: ‘starts_with’, width: 100 },
    the data looks like:
    “completedlist”:[{“crec”:{“id”:”1000000001″,”name”:”Has,Stine”,”score”:”174.0″}}
    ,{“crec”:{“id”:”1000000036″,”name”:”Schout, Lyn”,”score”:”162.0″}}
    ,{“crec”:{“id”:”1000000020″,”name”:”Chenny, John”,”score”:””}}
    ,{“crec”:{“id”:”1000004088″,”name”:”Simpson, Homer”,”score”:””}}
    ,{“crec”:{“id”:”1000005088″,”name”:”Pinkman, Jessie”,”score”:””}}
    ,{“crec”:{“id”:”1000006088″,”name”:”Ho, Monty”,”score”:””}}]
    The starts_with filter is valid only for String Columns, not for Numeric Columns(ID and Score). For numeric data you can use “less_than”, “greater_than”, etc. For more information about the filter types, see: jquery-grid-filtering.htm.
    Example:
    <script type="text/javascript" src="../../scripts/jquery-1.9.1.min.js"></script>
    var theme = getDemoTheme();
    var data = [{ "id": "1000000001", "name": "Has,Stine", "score": "174.0"}
    , { "id": "1000000036", "name": "Schout, Lyn", "score": "162.0"}
    , { "id": "1000000020", "name": "Chenny, John", "score": ""}
    , { "id": "1000004088", "name": "Simpson, Homer", "score": ""}
    , { "id": "1000005088", "name": "Pinkman, Jessie", "score": ""}
    , { "id": "1000006088", "name": "Ho, Monty", "score": ""}];
    { name: 'id', type: 'number'},
    { name: 'name', type: 'string' },
    { name: 'score', type: 'number' }
    localdata: data
    $("#jqxgrid").jqxGrid(
    width: 670,
    { text: 'Id', datafield: 'id', filtertype: 'textbox', filtercondition: 'less_than', width: 100 },
    { text: 'Name', datafield: 'name', filtertype: 'textbox', filtercondition: 'starts_with', width: 200 },
    { text: 'Score', datafield: 'score', filtertype: 'textbox', filtercondition: 'greater_than', width: 100 }
    <div id="jqxgrid"></div>
