jQuery UI Widgets Forums Grid Filter menu style and dimensions
This topic contains 4 replies, has 2 voices, and was last updated by  Gaetek 10 years, 9 months ago.
  • Filter menu style and dimensions #60619
    Gaetek
    I’m desperately trying to change the aspect of the filter menu, but i can’t find anything in the documentation or in the code itself.
    I just need reduce font and the size of the contents.
    Gaetano
    Filter menu style and dimensions #60621
    Hi Gaetano,
    The Filter Menu’s contents are not customizable. CSS Styles like fonts are defined in the Theme files like jqx.base.css
    Filter menu style and dimensions #60624
    Gaetek
    Do you mean I can change the font style for the menu itself, but not the content inside?
    If yes, what are the tags I should look for in base.css to change font size and family?
    Gatano
    Filter menu style and dimensions #60628
    Hi Gatano,
    No, you won’t be able to do that, because you don’t have access to the Menu’s HTML Element.
    Filter menu style and dimensions #60635
    Gaetek
    Hello again,
    I figured out an alternative way:
     $("div[id^='gridmenu']").css('min-width','210px');
     $("div[id^='gridmenu']").css('min-height','265px');
     $("div[id^='gridmenu']").css('font-family','Calibri, Candara, Segoe, "Segoe UI", Optima, Arial, sans-serif');
     $("div[id^='gridmenu']").css('font-size','10px');
     $("div[id^='menuItem99']").css('font-family','Calibri, Candara, Segoe, "Segoe UI", Optima, Arial, sans-serif');
     $("div[id^='menuItem99']").css('font-size','10px');
    This will allow changes on the filter menu at runtime.
    Gaetano
