jQuery UI Widgets › Forums › Grid › Filter -and- Edit Data
This topic contains 4 replies, has 2 voices, and was last updated by akshayyes 11 years, 6 months ago.
AuthorFilter -and- Edit Data Posts
1. Filter & Show Data – code working successfully on one page (data.php)
2. Update/Edit and Show Data – code working successfully on one page (data.php)
3. On combining – Update/Edit, Filter & Show Data on one page (data.php) – code NOT working on one page (data.php)
> Filter/Search command is executed successfully
>> But. update/edit is NOT WORKING`<!DOCTYPE html>
<html lang=”en”>
<link rel=”stylesheet” href=”../jqwidgets/styles/jqx.base.css” type=”text/css” />
<link rel=”stylesheet” href=”../jqwidgets/styles/jqx.classic.css” type=”text/css” />
<script type=”text/javascript” src=”../scripts/jquery-1.10.2.min.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxmenu.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxcheckbox.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxlistbox.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxdropdownlist.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxgrid.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxdata.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxgrid.selection.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxgrid.edit.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxgrid.pager.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxgrid.filter.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxinput.js”></script>
<script type=”text/javascript” src=”../jqwidgets/jqxwindow.js”></script>
var data = {};
var theme = ‘classic’;
{ name: ‘id’ },
{ name: ‘name’ },
{ name: ‘age’ }
url: ‘data.php’,
filter: function()
//alert(rowid);
// synchronize with the server – send update command//alert(data);
dataType: ‘json’,
url: ‘data.php’,
data: data,
commit(true);
error: function () {
// cancel changes.
commit(false);
// initialize the input fields.
$(“#name”).jqxInput({ theme: theme });
$(“#age”).jqxInput({ theme: theme });
$(“#jqxCheckBox2”).jqxCheckBox({ theme: theme });var dataAdapter = new $.jqx.dataAdapter(source);
var editrow = -1;// initialize jqxGrid
width: 1200,
height: 350,
selectionmode: ‘singlerow’,
source: source,
showfilterrow: true,
// virtualmode: true,
columns:
{ text: ‘Edit’, datafield: ‘Edit’, columntype: ‘button’, cellsrenderer: function () {
return “Edit”;
editrow = row;
$(“#popupWindow”).jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60 } });
//alert(getrowdata);
$(“#brand”).val(dataRecord.brand);
$(“#part_no”).val(dataRecord.part_no);
$(“#size”).val(dataRecord.size);
$(“#name”).val(dataRecord.outline_dimension);
$(“#jqxCheckBox2”).val(dataRecord.age);// show the popup window.
$(“#popupWindow”).jqxWindow(‘show’);
{ text: ‘OutlineDimension’, datafield: ‘outline_dimension’, width: 140 },
{ text: ‘production_status’, datafield: ‘production_status’, width: 140,columntype: ‘checkbox’},
width: 450, resizable: false, isModal: true, autoOpen: false, cancelButton: $(“#Cancel”), modalOpacity: 0.01
$(“#popupWindow”).on(‘open’, function () {
$(“#name”).jqxInput(‘selectAll’);
});$(“#Cancel”).jqxButton({ theme: theme });
$(“#Save”).jqxButton({ theme: theme });
// update the edited row when the user clicks the ‘Save’ button.
if (editrow >= 0) {var row = { name: $(“#name”).val(), age: $(“#age”).val()
//alert(row.brand);
var rowID = $(‘#jqxgrid’).jqxGrid(‘getrowid’, editrow);
//alert(rowID);
$(‘#jqxgrid’).jqxGrid(‘updaterow’, rowID, row);
<body class=’default’>
<div id=’jqxWidget’>
<div id=”jqxgrid”></div>
<div style=”margin-top: 30px;”>
<div id=”cellbegineditevent”></div>
<div style=”margin-top: 10px;” id=”cellendeditevent”></div>
<div id=”popupWindow”>
<div>Edit</div>
<div style=”overflow: hidden;”>
<table><tr>
<td align=”right”>name:</td>
<td align=”left”><input id=”name” /></td>
</tr>
<tr>
<td align=”right”>age:</td>
<td align=”left”><input id=”age” /></td>
</tr><tr>
<td align=”right”></td>
<td style=”padding-top: 10px;” align=”right”><input style=”margin-right: 5px;” type=”button” id=”Save” value=”Save” /><input id=”Cancel” type=”button” value=”Cancel” /></td>
</tr>
</table>
</html>Hi akshayyes,
The Ajax call in the provided code does not make any updates – the data variable points to an Empty Object which is incorrect. For doing CRUD, please refer to the PHP Integration help topics in the documentation or take a look at the “phpdemos” included in the download package.
http://www.jqwidgets.comI have myself removed the UPDATE command in the above post.
Now, I am using your code to run a test. It is run successfully when used as it is.
http://www.jqwidgets.com/jquery-widgets-documentation/documentation/phpintegration/php-server-side-grid-crud.htmWhen I added the FILTER command in your file (data.php), Then your code stops working.
I also added – Filter.js – in index.html file.
jqxGrid – Filterable Properties – is set TRUE.Please inform to me what is wrong with what I am doing ??
—— FILTER CODE —–
else if (isset($_GET['filterscount'])) { $filterscount = $_GET['filterscount']; if ($filterscount > 0) { $where = " WHERE ("; $tmpdatafield = ""; $tmpfilteroperator = ""; for ($i=0; $i < $filterscount; $i++) { // get the filter's value. $filtervalue = $_GET["filtervalue" . $i]; // get the filter's condition. $filtercondition = $_GET["filtercondition" . $i]; // get the filter's column. $filterdatafield = $_GET["filterdatafield" . $i]; // get the filter's operator. $filteroperator = $_GET["filteroperator" . $i]; if ($tmpdatafield == "") { $tmpdatafield = $filterdatafield; } else if ($tmpdatafield <> $filterdatafield) { $where .= ")AND("; } else if ($tmpdatafield == $filterdatafield) { if ($tmpfilteroperator == 0) { $where .= " AND "; } else $where .= " OR "; } // build the "WHERE" clause depending on the filter's condition, value and datafield. switch($filtercondition) { case "NOT_EMPTY": case "NOT_NULL": $where .= " " . $filterdatafield . " NOT LIKE '" . "" ."'"; break; case "EMPTY": case "NULL": $where .= " " . $filterdatafield . " LIKE '" . "" ."'"; break; case "CONTAINS_CASE_SENSITIVE": $where .= " BINARY " . $filterdatafield . " LIKE '%" . $filtervalue ."%'"; break; case "CONTAINS": $where .= " " . $filterdatafield . " LIKE '%" . $filtervalue ."%'"; break; case "DOES_NOT_CONTAIN_CASE_SENSITIVE": $where .= " BINARY " . $filterdatafield . " NOT LIKE '%" . $filtervalue ."%'"; break; case "DOES_NOT_CONTAIN": $where .= " " . $filterdatafield . " NOT LIKE '%" . $filtervalue ."%'"; break; case "EQUAL_CASE_SENSITIVE": $where .= " BINARY " . $filterdatafield . " = '" . $filtervalue ."'"; break; case "EQUAL": $where .= " " . $filterdatafield . " = '" . $filtervalue ."'"; break; case "NOT_EQUAL_CASE_SENSITIVE": $where .= " BINARY " . $filterdatafield . " <> '" . $filtervalue ."'"; break; case "NOT_EQUAL": $where .= " " . $filterdatafield . " <> '" . $filtervalue ."'"; break; case "GREATER_THAN": $where .= " " . $filterdatafield . " > '" . $filtervalue ."'"; break; case "LESS_THAN": $where .= " " . $filterdatafield . " < '" . $filtervalue ."'"; break; case "GREATER_THAN_OR_EQUAL": $where .= " " . $filterdatafield . " >= '" . $filtervalue ."'"; break; case "LESS_THAN_OR_EQUAL": $where .= " " . $filterdatafield . " <= '" . $filtervalue ."'"; break; case "STARTS_WITH_CASE_SENSITIVE": $where .= " BINARY " . $filterdatafield . " LIKE '" . $filtervalue ."%'"; break; case "STARTS_WITH": $where .= " " . $filterdatafield . " LIKE '" . $filtervalue ."%'"; break; case "ENDS_WITH_CASE_SENSITIVE": $where .= " BINARY " . $filterdatafield . " LIKE '%" . $filtervalue ."'"; break; case "ENDS_WITH": $where .= " " . $filterdatafield . " LIKE '%" . $filtervalue ."'"; break; } if ($i == $filterscount - 1) { $where .= ")"; } $tmpfilteroperator = $filteroperator; $tmpdatafield = $filterdatafield; } // build the query. $query = "SELECT * FROM employees" . $where; } }
How to ADD the – FILTER code – {http://www.jqwidgets.com/jquery-widgets-demo/demos/php/index.htm?%28arctic%29?%28arctic%29#demos/php/serverfiltering.htm} IN http://www.jqwidgets.com/jquery-widgets-documentation/documentation/phpintegration/php-server-side-grid-crud.htm
Hello Peter,
How to ADD – ServerFiltering – along with – http://www.jqwidgets.com/jquery-widgets-documentation/documentation/phpintegration/php-server-side-grid-crud.htmPlease reply. Thanks
