jQuery UI Widgets Forums Grid Few Lines of Code – Nested Grid issue
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 9 years, 10 months ago.
  • Keshavan
    Hi Dimitar,
    as required by you, please fine below few lines of relevant code for the issue, pleas suggest solution.
    Keshavan
    Nested Grid – DRag/Drop implementation details.
    Outer grid name – orderheaderGrid
    Inner grid name – grid
    Name of the Other Grid (seperate from Nested Grid) – orderdetailGrid.
    Nested Grid is properly implemented and is working OK. orderdetail grid is seperately working OK.
    Issue only in Drag-Drop.
    I have Implemented Drag-Drop from the above mentioned Other Grid(orderdetailGrid) in to inner grid (name of Grid – grid) of nested Grid.
    With below drag-drop implementation , i am referenncing “cell” in dragend as in the below line,
    cell = $(“#grid”).jqxGrid(‘getcellatposition’, position.left, position.top);
    Browser Console displayed – Invalid selctor – check Id or Css.
    when i checked the Id programatically, in Nested Grid, The Inner grid (name of Grid : grid) the Id was grid0, grid1, grid2, …. gridn depending
    on the row of the outer grid of nested grid.
    so i used, var grid = “grid” + referencerow; in dragend code (pasted below).
    referencerow is a global variable.
    // nested grid rowclick binding
    $(“#grid”).on(“rowclick”, function (event) {
    var args = event.args;
    var rowindex = args.rowindex;
    referencerow = rowindex;
    Now , browser console shows NO error but Drop doesn’t happen, the target row remains blank.
    $(“#orderdetailGrid”).jqxGrid(
     width: 945,
     height: 400,
     theme: ‘ui-sunny’,
     groupable: true,
     columnsreorder: true,
     keyboardnavigation: false,
     enabletooltips: true,
     rendered: function (type) {
     // select all grid cells.
     var gridCells = $(‘#orderdetailGrid’).find(‘.jqx-grid-cell’);
     // initialize the jqxDragDrop plug-in. Set its drop target to the second Grid.
     gridCells.jqxDragDrop({
     appendTo: ‘body’, theme: “ui-sunny”, dragZIndex: 99999,
     dropAction: ‘none’,
    initFeedback: function (feedback) {
     feedback.height(25);
     onTargetDrop: function (a, b, c, d, e) {
     dropTarget: $(‘#grid0′), revert: true
     gridCells.off(‘dragStart’);
    gridCells.off(‘dragEnd’);
    gridCells.off(‘dropTargetEnter’);
    gridCells.off(‘dropTargetLeave’);
     // disable revert when the dragged cell is over the second Grid.
     gridCells.on(‘dropTargetEnter’, function () {
     gridCells.jqxDragDrop({ revert: false });
     // enable revert when the dragged cell is outside the second Grid.
     gridCells.on(‘dropTargetLeave’, function () {
     gridCells.jqxDragDrop({ revert: true });
     // initialize the dragged object.
     gridCells.on(‘dragStart’, function (event) {
     var value = $(this).text();
     var position = $.jqx.position(event.args);
     var cell = $(“#orderdetailGrid”).jqxGrid(‘getcellatposition’, position.left, position.top); // original line
     refdata = 0; // ADDED 30 jan 2014
     refdata = $(‘#orderdetailGrid’).jqxGrid(‘getcellvalue’, cell.row, “OrderDetailId”); // ADDED 30 jan 2014
     $(this).jqxDragDrop(‘data’, {
    value: value
     // set the new cell value when the dragged cell is dropped over the second Grid.
     gridCells.on(‘dragEnd’, function (event) {
     oldvalue = 0;
     var idx = 0;
     var valueDesc = $(this).text();
     var cell;
     Rcell = cell;
     if (valueDesc != null) {
     // idx = getItemIndex(valueDesc + refdata); // ADDED refdata on 30 Jan 2014
     idx = 1;
     if (idx != -1) {
     if (cell != null) {
     var vd2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, ” ProductDesc”);
    var aq2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “OrderQty”);
    var pq2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “PendingShipQty”);
    var sid = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “ShipId”);
    var oid = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “OrderId”);
    if ((vd2 == null) && (aq2 != 0 || pq2 != 0) && (orefid == oid)) { // changed both from /
     //addded oid==gid
     cartItems.push(valueDesc);
     $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “ProductDesc”, valueDesc);
     $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “ProductCode”, pc);
     $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “OrderQty”, stockqty);
     $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “PendingShipQty”, psquantity);
     $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “OrderDetailId”, odid);
     $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “StockQty”, invqty);
     cartItems.push(valueDesc + refdata);// ADDED refdata on 30 Jan 2014
     var sri = 0;
     valueDesc = ” “; // added today
     else {
     alert(“Drop properly on a empty row / add new row / check OrderId, Drag and drop item on it !!!”);
    else {
     var sq2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “OrderQty”);
    oldvalue = sq2;
     alert(“Item already exists !!! “);
    My HTML is as below,
    <body class=’default’>
     <div id=’jqxWidget’ style=”font-size: 13px; font-family: Verdana; float: left;”>
     <div id=”orderheaderGrid”></div>
     <div id=”grid”></div>
     <div id=”orderdetailGrid” style=”margin-left: 1px; margin-top: 7px;”></div>
