jQuery UI Widgets Forums Chart Facing problem with PIE chart
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 10 years, 8 months ago.
  • Facing problem with PIE chart #63469
    harishmaney
    Sorry for posting the wrong question in wrong forum.
    Here is my sample code snippet…
    function drawPieTokenChart() {
    datatype: “csv”,
    { name: ‘Token’ },
    { name: ‘Count’ }
    url: $(‘#hdnPieChartData’).val() + ‘?t=’ + new Date().getTime()
    async: false, autoBind: true, loadError: function (xhr, status, error) { //alert(‘Error loading “‘ + source.url + ‘” : ‘ + error);
    // prepare jqxChart settings
    var settings = {
    title: token,
    description: “”,
    enableAnimations: true,
    showLegend: true,
    showBorderLine: true,
    //padding: { left: 5, top: 5, right: 5, bottom: 5 },
    //titlePadding: { left: 0, top: 0, right: 0, bottom: 10 },
    colorScheme: ‘scheme03’,
    seriesGroups:
    type: ‘pie’,
    showLabels: false,
    series:
    dataField: ‘Count’,
    displayText: ‘Token’,
    labelRadius: 45,
    initialAngle: 0,
    radius: 125,
    centerOffset: 0,
    offsetY: 200,
    formatFunction: function (value) {
    if (isNaN(value))
    return value;
    return parseFloat(value) + ‘%’;
    // setup the chart
    $(‘#pieChart’).jqxChart(settings);
    $(‘#hdnPieChartData’).val() – contains the path of the csv file from where I am reading the data.
    Harish
    Facing problem with PIE chart #63478
    Hello Harish,
    Instead of your formatFunction, you may try applying the formatSettings property as follows:
    formatSettings: { sufix: '%' }
    If the issue persists, please share some sample data so that we may test your code. Remember to format your sample snippet by selecting it and pressing the code button in the toolbar.
    Facing problem with PIE chart #63512
    harishmaney
    Hi Dimitar,
    Still, it does not solve the issue of NaN. If I remove formatFunction and use formatSettings {sufix:’%’}, I can still see an empty legend displayed.
    Any idea, why?
    Harish. P
    Facing problem with PIE chart #63514
    Hi Harish. P,
    Please share some sample data so that we may test your code and see what causes the issue. Remember to format your sample snippet by selecting it and pressing the code button in the toolbar. Alternatively, post a JSFiddle example.
