jQuery UI Widgets Forums Grid exportview time offset issue
This topic contains 1 reply, has 2 voices, and was last updated by  admin 1 year, 2 months ago.
  • exportview time offset issue #134359
    jlarue
    I am using exportView to create an excel spreadsheet with the grid. The grid contains a date/time column that I am formatting as hh:mm tt. When the data is rendered in excel, the time in that column is being offset by +5 hours.
    for example, the value coming from the server is 2024-02-20T11:51:29.893. it is being sent to excel as 4:51PM.
    See a working example here https://jseditor.io/?key=boilerplate.
    Do i have any control over how this behaves?
    thank you!
    exportview time offset issue #134361
    admin
    Hi jlarue,
    This is the time-zone difference between your time zone and the time-zone used by Excel – the UTC time zone. The Grid displays your dates in your time zone while excel does not.
    Peter
