jQuery UI Widgets Forums Plugins Data Adapter error with dataAdapter using .asmx ASP .NET json data
This topic contains 2 replies, has 2 voices, and was last updated by  cflowers 9 years, 6 months ago.
  • cflowers
    Getting error
    SyntaxError: Unexpected token <<?xml version= "1.0" encoding="utf-8?>>][{"Name":"about"},{"Name":"about2"}... more data...}]</anyType>
    I’m trying to get autocomplete to work with jqxInput and jqx.DataAdapter. Here is my code:
    Reports.asmx
            [WebMethod(EnableSession = true)]
            [ScriptMethod(UseHttpGet = true, ResponseFormat = ResponseFormat.Json)]
            public object GetIntellisense(string pattern )
                try
                    using (var proxy = GTS.Client.GTSWebServiceFactory.CreateReportProxy())
                        List<Intellisense> intellisenseList = new List<Intellisense>();
                        List<string> names = proxy.GetReportIntellisense("DocumentActivity", "DocumentSearch", pattern + "%");
                        for (int i = 0; i < names.Count; i++)
                            Intellisense x = new Intellisense();
                            x.Name = names[i];
                            intellisenseList.Add(x);
                        proxy.Close();
                        JavaScriptSerializer js = new JavaScriptSerializer();
                        string json = js.Serialize(intellisenseList);
                        return json;  // getting here with good json data
                catch (Exception exc)
                    GTS.Logging.Log.Warn("error getting intellisense", exc);
                    throw new Exception(exc.Message);
    in DocumentActivity.aspx
    <input id="documentName" />
    $("#documentName").jqxInput({
                    source: function (pattern, response) {
                        var dataAdapter = new $.jqx.dataAdapter (
                                    type: "GET",
                                    //contentType: "application/json; charset=utf-8", // if this is uncommented then GetIntellisense is not called
                                    async: false,
                                    data: "{ 'pattern': '" + pattern + "' }",
                                    url: 'Reports.asmx/GetIntellisense',
                                    	{ name: 'Name', type: 'string' }
                                    cache: false,
                                    root: 'data'
                                    autoBind: true,
                                    formatData: function (data) {
                                        data.pattern = pattern;
                                        return data;
                                    downloadComplet: function(data, textStatus, jqXHR) {
                                        return data.d;
                                        alert(error + xhr.responseText);
                    placeHolder: "Enter a document name",
                    height: 25,
                    width: 200,
                    minLength: 1    // MINIMUM 1 CHARACTER TO START WITH.
    Not sure why the json data is coming back with header information. Can you advise?
    Thanks in advance.
    Hi cflowers,
    If your JSON contains: “< ” then it should be expected that there is an exception because this is not JSON, but XML.
    cflowers
    For anyone looking to see how I solved this issue:
            [ScriptMethod(UseHttpGet = false, ResponseFormat = ResponseFormat.Json)]
            public object GetIntellisense(/*string corrkey, string reportName, string paramName,*/ string pattern)
                try
                    Context.Response.Clear();
                    Context.Response.ContentType = "application/json";
                            x.Name = names[i];
                        proxy.Close();
                        object oJson = js.DeserializeObject(json); // needed to deserialize object before returning.
                        return oJson;
    	                        type: 'POST',
    	                        dataType: 'json',
    	                        async: true,
    	                        url: "Reports.asmx/GetIntellisense",
                                cache: false,
                                contentType: 'application/json; charset=utf-8',
    	                        autoBind: true,
    	                            data.pattern = pattern;  // make sure name is same as paramater
    	                            return JSON.stringify(data); // Needed to stringify data
    	                            if (data.d.length > 0) {
    	                                response($.map(data.d, function (item) {
    	                                    return item.Name
                    height: 25,
                    width: 200,
