jQuery UI Widgets › Forums › Scheduler › Ensure Appointment VIsible for MonthView and EnsureVisible for Date issue
Tagged: ensureAppointmentVisible, ensureVisible, scheduler
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 7 years, 11 months ago.
June 21, 2017 at 12:40 pm Ensure Appointment VIsible for MonthView and EnsureVisible for Date issue #94456
I have two issues with the Scheduler:
1. The ‘ensureAppointmentVisible’ doesn’t work for me in the <monthView>. It functions properly in <dayView>, and <weekView>.
2. The ‘ensureVisible’ function doesn’t work for me to move to a specific date.
$("#myCalendar").jqxScheduler('ensureVisible', new $.jqx.date(2017, 4, 1))
This works fine however so I’ve been using this instead.
$("#myCalendar").jqxScheduler({ date: new $.jqx.date(2017, 4, 1) });
Any help would be appreciated regarding these two issues.
Satch(Test code demonstrating the above issues)
<script type="text/javascript" > $(document).ready(function () { $("#goDateBut1").jqxButton({ width: '250', height: '25' }) .on('click', function () { // <ensureVisible> doesn't work $("#myCalendar").jqxScheduler('ensureVisible', new $.jqx.date(2017, 4, 1)); $('#myCalendar').jqxScheduler('selectCell', new $.jqx.date(2017, 4, 1) , true, ""); }); $("#goDateBut2").jqxButton({ width: '150', height: '25' }) .on('click', function () { //This works $("#myCalendar").jqxScheduler({ date: new $.jqx.date(2017, 4, 1) }); $('#myCalendar').jqxScheduler('selectCell', new $.jqx.date(2017, 4, 1), true, ""); }); $("#goAptBut").jqxButton({ width: '150', height: '25' }) .on('click', function () { //works for Day and Week view, doesn't work for month view $("#myCalendar").jqxScheduler('ensureAppointmentVisible', 'apptId1'); }); var appointments = new Array(); var appointment1 = { id: "apptId1", description: "My Appointment", location: "Field A", subject: "Fireworks", calendar: "Event A", start: new Date(2017, 7, 4, 9, 0, 0), end: new Date(2017, 7, 4, 11, 0, 0) } appointments.push(appointment1); var source = { dataType: "array", dataFields: [ { name: 'id', type: 'string' }, { name: 'description', type: 'string' }, { name: 'location', type: 'string' }, { name: 'subject', type: 'string' }, { name: 'calendar', type: 'string' }, { name: 'start', type: 'date' }, { name: 'end', type: 'date' } ], id: 'id', localData: appointments }; var adapter = new $.jqx.dataAdapter(source); $("#myCalendar").jqxScheduler({ date: new $.jqx.date(2017, 1, 1), source: adapter, view: 'monthView', showLegend: true, resources: { dataField: "calendar", source: new $.jqx.dataAdapter(source) }, appointmentDataFields: { from: "start", to: "end", id: "id", description: "description", location: "place", subject: "subject", resourceId: "calendar" }, views: ['dayView', 'weekView', 'monthView' ] }); }); </script> </head> <body> <div id="myCalendar"></div> <input type="button" value="Go Date 4/1/2017 (ensureVisible)" id='goDateBut1' /> <input type="button" value="Go Date 4/1/2017" id='goDateBut2' /><br /><br /> <input type="button" value="Go Appointment" id='goAptBut' /> </body> </html>
June 22, 2017 at 12:30 pm Ensure Appointment VIsible for MonthView and EnsureVisible for Date issue #94485I think here is misunderstanding what ensureVisible and ensureAppointmentVisible should do. These methods only change the Scrollbar position to a date in the Current View and if there is a scrollbar. It will not navigate to a different view.
