jQuery UI Widgets Forums Grid Enabled paging or not
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 4 months ago.
  • Enabled paging or not #14243
    christophe67
    Is there a possibility to enabled the paging and disabled, because when you put in the pagesizeoptions [‘All’,’5′,’10’….]
    ALL is not a valide param, by default you have 10.
    Thanks for your help
    Christophe
    Enabled paging or not #14259
    Hi Christophe,
    In the pagesizeoptions, you can put only numbers. “All” option could not be added in the default pager. You can learn how to create a custom pager from this sample: custompager.htm.
