jQuery UI Widgets Forums Editors Editor Editor not working with Panel
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 5 years, 3 months ago.
  • Editor not working with Panel #108185
    alperdincer
    I’m creating multiple Editors on single jqxWindow with jqxPanel to show scroll if needed, but editors is not working when I initialized panel at start. When I initialised panel after few seconds (5 seconds) they seemed to be working, but the initial values will disappeared after panel initialisation.
    What are you suggesting for this conflict?
    Editor not working with Panel #108225
    Hello alperdincer,
    Could you provide us with one simplified example that demonstrates your case?
    Before that, I would like to suggest something that you could check.
    It is important for the jqxWindow when creating the widgets that are in its content.
    It is important to create them in the initContent callback.
    Let me know if this does not help you.
    https://www.jqwidgets.com
