jQuery UI Widgets Forums Grid Editing JqxComboBox inside JqxGrid issue
This topic contains 4 replies, has 2 voices, and was last updated by  nitinjambhale 8 years, 9 months ago.
  • Editing JqxComboBox inside JqxGrid issue #88811
    nitinjambhale
    How do I edit(add new) item in jqxComboBox inside jqxGrid.
    Currently when I add new item in it, its getting blank
    Editing JqxComboBox inside JqxGrid issue #88827
    Christopher
    Hi nitinjambhale,
    New items are added as a source to the jqxComboBox. In a scenario where the jqxComboBox is used as a columtype for a column in a jqxGrid it uses the Grid’s source. You can also set a separate data source to the jqxComboBox if you like. Please provide a code sample so we can understand what exactly is the difficulty you’re facing.
    Christopher
    Editing JqxComboBox inside JqxGrid issue #88834
    nitinjambhale
    There is a separate datasource for jqxComboBox..
    Here is the code…
      $("#myGrid").jqxGrid(
                    height: gridHeight,
                    //width: gridwidth,
                    source: source,
                    sortable: false,
                    pageable: false,
                    autoheight: false,
                    autowidth: true,
                    columnsreorder: false,
                    enabletooltips: true,
                            text: "PLine", datafield: "MPLineID", displayfield: 'Pl', columntype: 'combobox', width: 250, editable: true,
                            createeditor: function (row, column, editor) {
                                // assign a new data source to the combobox.
                                editor.jqxComboBox({ source: dataAdapterpl, displayMember: "Pl", valueMember: "MPLineID", autoComplete: true });
                                editor.bind('select', function (event) {
                                    if (event.args != undefined) {
                                        var item = event.args.item;
                                        if (item) {
                                            //var value = item.value;
                                            var label = item.label;
                                            GetPlDetailsNew(label);
                            // update the editor's value before saving it.
                            cellvaluechanging: function (row, column, columntype, oldvalue, newvalue) {
                                // return the old value, if the new value is empty.
                                if (newvalue == "") return oldvalue;
        $("#myGrid").on('cellbeginedit', function (event) {
            var args = event.args;
            var columnDataField = args.datafield;
            var rowIndex = args.rowindex;
            var cellValue = args.value;
        $("#myGrid").on('cellendedit', function (event) {
            var oldValue = args.oldvalue;
            $(args).jqxComboBox('addItem', args.value);
            //$(args).jqxComboBox('addItem', { label: args.value, value: '0' });
            $("#myGrid").jqxGrid('setcellvalue', "Pl", args.value);
    Editing JqxComboBox inside JqxGrid issue #88871
    Christopher
    Hi nitinjambhale,
    $(args).jqxComboBox('addItem', args.value); The problem is that “args” isn’t valid. “args” doesn’t contain an instance of the jqxComboBox. You need to create a global variable for example “comboBoxInstance” and in the “createeditor” function assign the instance of the jqxComboBox to that variable, so you can later make a call to it in the cellendedit function. Here’s what i have in mind:
    var comboBoxInstance;
                $("#myGrid").jqxGrid {
                            text: 'Country', datafield: 'countryCode', displayfield: 'Country', columntype: 'combobox', editable: true,
                                editor.jqxComboBox({ source: countriesAdapter, displayMember: 'label', valueMember: 'value', multiSelect: true });
                                comboBoxInstance = editor;
            comboBoxInstance.jqxComboBox('addItem', args.value);
            //$(comboBoxInstance).jqxComboBox('addItem', { label: args.value, value: '0' });
    Christopher
    Editing JqxComboBox inside JqxGrid issue #89009
    nitinjambhale
    Thnx Christopher…Its Done!!!
