jQuery UI Widgets Forums Grid Editable date column with min and max
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 8 years, 4 months ago.
  • Editable date column with min and max #90570
    stlredlink
    we use a editable date column with a min and max date specified – see http://jsfiddle.net/fgn56tj8/2/. When the cell is empty and you click on the datepicker icon than the datepicker shows the current month. The problem is that min and max date are not lying within the current month. We would expect that the month that matches the min date would be shown by default. To make matters worse we can’t even change the month in the datepicker.
    Any ideas how to solve that problem?
    Best regards
    Editable date column with min and max #90589
    Hi stiredlink,
    You can implement the initeditor and set the DateTimeInput Grid editor’s value.
    Example:
      var datafields = [
                        {name: 'id', type: 'number'},
                        {name: 'start', type: 'date'},
                        {name: 'name', type: 'string'}
                    source =
                        localdata: [
                            {id: 1, start: '', name: 'Unit-A'},
                            {id: 2, start: '2015-01-01', name: 'Unit-B'},
                            {id: 3, start: '2017-01-01', name: 'Unit-C'},
                            {id: 4, start: '2016-01-01', name: 'Unit-D'}
                        datatype: 'array',
                        datafields: datafields,
                    dataAdapter = new $.jqx.dataAdapter(source);
                $('#jqxgrid').jqxGrid(
                        width: 600,
                            {text: 'ID', datafield: 'id', hidden: true},
                                text: 'Start',
                                datafield: 'start',
                                width: 120,
                                cellsformat: 'dd.MM.yyyy',
                                columntype: 'datetimeinput',
                                createeditor: function (rowIndex, cellValue, editor) {
                                    editor.jqxDateTimeInput({min: new Date(2017, 4, 17), max: new Date(2017, 4, 23)});
                                initeditor: function(rowindex, cellvalue, editor) {
        editor.jqxDateTimeInput({value: new Date(2017, 4, 17)});
                            {text: 'Name', datafield: 'name'}
    Editable date column with min and max #90827
    stlredlink
    well, yes that would work but seems more like a workaround for an obvious bug.
    Problem with this workaround is is that e.g. an user maybe accidentally clicks on such an editable date column and than a date will be inserted although it wasn’t users intention.
    Best regards
    Editable date column with min and max #90833
    Hi stlredlink,
    Thank you for your opinion. We will take it into consideration.
