jQuery UI Widgets › Forums › DataTable › Edit with dialog box: DropdownList problem
This topic contains 1 reply, has 2 voices, and was last updated by ivailo 9 years, 10 months ago.
I have a datatable that I would like to edit thanks to a dialog box.
In the dialog box I have a dropdownlist but i can’t set the value of the dropdownlist with the value of the row.Here is my code:
var source = { dataType: "json", datafields: [ { name: 'brand', type: 'string' } ], localData: Branddata, async: false }; var dataAdapter = new $.jqx.dataAdapter(source); var sourceTable = { dataType: "array", dataFields: [ { name: 'ID', type: 'string' }, { name: 'Company', type: 'string' } ], id: 'ID', localData: data, updateRow: function (rowID, rowData, commit) { commit(true); } }; var dataAdapterTable = new $.jqx.dataAdapter(sourceTable); $("#dataTable").jqxDataTable( { source: dataAdapterTable, editable: true, ready: function () { $("#ID").jqxInput({ disabled: true, width: 150, height: 30 }); $("#Company").jqxDropDownList({ theme: 'bootstrap', source: dataAdapter, displayMember: "brand", valueMember: 'ID', width: 100, height: 25, autoDropDownHeight: true }); $("#save").jqxButton({ height: 30, width: 80 }); $("#cancel").jqxButton({ height: 30, width: 80 }); $("#cancel").mousedown(function () { // close jqxWindow. $("#dialog").jqxWindow('close'); }); $("#save").mousedown(function () { // close jqxWindow. $("#dialog").jqxWindow('close'); // update edited row. var editRow = parseInt($("#dialog").attr('data-row')); var rowData = { ID: $("#ID").val(), Company: $("#Company").val() }; $("#dataTable").jqxDataTable('updateRow', editRow, rowData); }); $("#dialog").on('close', function () { // enable jqxDataTable. $("#dataTable").jqxDataTable({ disabled: false }); }); $("#dialog").jqxWindow({ resizable: false, position: { left: $("#dataTable").offset().left + 200, top: $("#dataTable").offset().top + 400 }, width: 370, height: 330, autoOpen: false }); $("#dialog").css('visibility', 'visible'); }, columns: [ { text: 'ID', dataField: 'ID', editable: false, align: 'center', cellsAlign: 'center' }, { text: 'Company', dataField: 'Company', align: 'center', cellsAlign: 'center'} ] }); $("#dataTable").on('rowDoubleClick', function (event) { var args = event.args; var index = args.index; var row = args.row; $("#dialog").jqxWindow('setTitle', "Edit Row: " + row.ID); $("#dialog").jqxWindow('open'); $("#dialog").attr('data-row', index); $("#dataTable").jqxDataTable({ disabled: true }); $("#ID").val(row.ID); $("#Company").val(row.Company); }); <div id="dialog"> <div>Edit</div> <div style="overflow: hidden;"> <table> <tr> <td align="right">ID:</td> <td align="left"><input id="ID" /></td> </tr> <tr> <td align="right">Company:</td> <td align="left"><div id="Company"></div></td> </tr> <tr> <td align="right"></td> <td style="padding-top: 10px;" align="right"><input style="margin-right: 5px;" type="button" id="save" value="Save" /><input id="cancel" type="button" value="Cancel" /></td> </tr> </table> </div> </div>
Could you help to see where is the error?
ThanksHi tranen,
In your dataAdapter’s source you don’t have datafield named ID, used like a valueMember.
Ivailo IvanovjQWidgets Team
