jQuery UI Widgets › Forums › Lists › DropDownList › DropDownList issue on IE 11
Tagged: AssetypeDropdonwlist, bootstrap dropdownlist, DropDownList, javascript dropdownlist, jQuery DropDownList, jqwidgets dropdownlist, jqxDropDownList
This topic contains 4 replies, has 2 voices, and was last updated by Hristo 9 years ago.
HI,
We are using jQWidget304 version. Application is running fine in IE 8 and google crome. But when we tested it on IE 11 its dropdownList is not working properly. Issue is when I click on textbox the dropdownlist appears and when I hovour the mouse on dropdownlist its getting invisible or hidden..not sure what is the issue.
Code sample is as follows.<div id=”assetTypeContainer”>
<input type=’text’ id=”dropdownProductBtn” style=’width: 500px; font-size: 11px; font-family: Verdana;’ onClick=”this.select();” onfocus=’javascript:productTables.showMenu()’ onkeyup=’javascript:productTables.filterMenu()’/>
<div id=”dropdownProduct” onblur=’javascript:productTables.closeMenu()’></div>
</div>`productTables.showMenu = function () { $("#dropdownProduct").css({ 'visibility': 'visible', 'display': 'block', 'position': 'absolute', 'z-index': '999' }); };
datafields: prodHierarchyFields,
url: dfGlobals.webroot + “Product/GetProductsHierarchy”,
async: false
// create data adapter.
var dataAdapter = new $.jqx.dataAdapter(source);// perform Data Binding.
dataAdapter.dataBind();
dfGlobals.productData = dataAdapter.records;var records = dataAdapter.getRecordsHierarchy(‘id’, ‘parentid’, ‘items’, [{ name: ‘text’, map: ‘label’}]);
$(‘#dropdownProduct’).jqxMenu({ source: records, mode: ‘vertical’, theme: dfGlobals.theme, width: ‘200px’ });
$(“#dropdownProduct”).css({ ‘visibility’: ‘hidden’, ‘display’: ‘none’ });$(“#dropdownProduct”).on(‘itemclick’, function (event) {
if (isChild(dataAdapter.records, event.args.id)) {$(“#dropdownProduct”).css({ ‘visibility’: ‘hidden’, ‘display’: ‘none’ });
$(“input#dropdownProductBtn”).val($(event.args).text());
$(“input#dropdownProductBtn”).addClass(“productClass”);
dfGlobals.selProductId = event.args.id;
var items = [];
items = $.grep(dfGlobals.productData, function (element, index) {
var flag = (element[‘id’] && element[‘id’] == event.args.id);
return flag;
});if (items && items.length > 0) {
dfGlobals.selectedProduct = items[0];
dfGlobals.selTaxonomyId = items[0].taxonomyFlagId;if (productCheck.enableVolSEF()) {
$(‘#volSEF’).jqxCheckBox(‘enable’);
} else {
$(‘#volSEF’).jqxCheckBox(‘uncheck’);
$(‘#volSEF’).jqxCheckBox(‘disable’);
}if (productCheck.enableClearing()) {
$(‘#cleared’).jqxCheckBox(‘enable’);
} else {
$(‘#cleared’).jqxCheckBox(‘uncheck’);
$(‘#cleared’).jqxCheckBox(‘disable’);
}if (productCheck.enableMandatorySEF()) {
$(‘#matSEF’).jqxCheckBox(‘enable’);
} else {
$(‘#matSEF’).jqxCheckBox(‘uncheck’);
$(‘#matSEF’).jqxCheckBox(‘disable’);
if (!$(“#cleared”).jqxCheckBox(‘checked’)) {
$(‘#segIA’).jqxCheckBox(‘enable’);
} else {
$(‘#segIA’).jqxCheckBox(‘disable’);
displayProduct();
});$(“#dropdownAssetType”).jqxDropDownList({
selectedIndex: -1,
source: dataAdapters.AssetClass,
displayMember: “text”,
valueMember: “id”,
autoDropDownHeight: true,
width: 170,
dropDownWidth: 210,
height: 20,
}).bind(‘select’, function (event) {
$(“#jqxgridProductsIn”).fadeTo(“fast”, 0.2);
var assetId = event.args.item ? event.args.item.value : “-1”;
if (dfGlobals.selProduct.length > 0) {
dfGlobals.selProduct.splice(0, dfGlobals.selProduct.length);
}var products = $.grep(dfGlobals.productData, function (element, index) {
return (element[‘level1’] == assetId && element[‘isLeaf’]);
});$.each(products, function (index, value) {
dfGlobals.selProduct.push(value);
`Hello nravhad,
We recommend to use latest version of jQWidgets.
Please, send Your code in (https://www.jseditor.io/ or https://fiddle.jshell.net/) if you still have same issue.Best Regards,
Hristo HristovjQWidgets team
http://www.jqwidgets.comHi Hristo,
Please visit the following link to see the code..
https://www.jseditor.io/?key=dropdown-issue-1I could not go for latest version only for dropdown issue as it is not a feasible because other jQWidgets components are working fine on IE 11.
Could you please help on the existing scenario.Thanks,
NileshHi Hristo,
I found the root cause for this issue. I have a closeMenu function which I am calling on the focusOut event of the dropdownProductBtn which shows the dropdown on its click.
Below is my HTML.
<input type='text' id="dropdownProductBtn" style='width: 500px; font-size: 11px; font-family: Verdana;' onClick="this.select();" onfocus='javascript:productTables.showMenu()' onkeyup='javascript:productTables.filterMenu()'/>
The root cause is that CloseMenu function is getting called on its onClick event of dropdownProductBtn not sure how and why. If I disable that event Its resolves the issue but causing other functionality breaks.
Could you please help how I can disable the closeMenu event on dropdownProductBtn click.
Below is my JS.productTables.showMenu = function () { $("#dropdownProduct").css({ 'visibility': 'visible', 'display': 'block', 'position': 'absolute', 'z-index': '999' }); };
$("input#dropdownProductBtn").on('focusout', function () { actiondata.getEMIRMCEligProductDetails(); productTables.closeMenu(); });
productTables.closeMenu = function () { $("#dropdownProduct").css({ 'visibility': 'hidden', 'display': 'none' }); };
Hello nravhad,
Please, provide us example that is contain only Menu (as much as possible – small code size with jqxMenu) to demonstrate this issue.
