jQuery UI Widgets Forums Grid Dropdown in Grid – Usage Issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 2 months ago.
  • Dropdown in Grid – Usage Issue #17885
    Keshavan
    I have a grid in which the first 2 columns are of type ‘Dropdownlist’.
    I have 3 data sources accordingly for the 2 ‘dropdowns’ and 1 for the main grid.
    I have 3 adapters for the 3 sources , I have used ‘autobind’ w.r.t the 2 data sources for the 2 dropdowns.
    Is there any limit to the no of adapters in a Grid ?.
    Please let me know if the below code is wit out errors,
    $(document).ready(function ()
    // prepare data from external GroupCompany entity
    var source1 =
    datafields:
    { name: ‘CompanyId’ },
    { name: ‘CompanyName’ }
    url: ‘Company/GetPartCompanies’,
    async: false
    var dataAdapater1 = new $.jqx.dataAdapter(source1, { autoBind: true })
    var source2 =
    datafields:
    { name: ‘DepartmentId’ },
    { name: ‘DepartmentName’ }
    url: ‘Department/GetPartDepartments’,
    async: false
    var dataAdapater2 = new $.jqx.dataAdapter(source2, { autoBind: true })
    var data = {};
    var generaterow = function (id)
    var row = {};
    row[“EmployeeId”] = id;
    row[“CompanyId”] = 1;
    row[“DepartmentId”] = 1;
    row[“EmployeeCode”] = ” “;
    row[“EmployeeName”] = ” “;
    row[“MobileNo”] = ” “;
    row[“EmailId”] = ” “;
    row[“Active”] = 1;
    return row;
    var source3 =
    datafields:
    { name: ‘EmployeeId’ },
    { name: ‘CompanyId’, value: ‘CompanyId’, values: { source: dataAdapater1.records,
    value: ‘CompanyId’, name: ‘CompanyName’
    { name: ‘CompanyName’ },
    { name: ‘DepartmentId’, value: ‘DepartmentId’, values: { source: dataAdapater2.records,
    value: ‘DepartmentId’, name: ‘DepartmentName’
    { name: ‘DepartmentName’ },
    { name: ‘Employeecode’ },
    { name: ‘EmployeeName’ },
    { name: ‘MobileNo’ },
    { name: ‘EmailId’ },
    { name: ‘Active’ }
    url: ‘Employee/GetEmployees’,
    var dataAdapater3 = new $.jqx.dataAdapter(source3);
    $(“#jqxgrid”).jqxGrid(
    width: 950,
    height: 350,
    source: dataAdapater3,
    theme: ‘ui-smoothness’,
    selectionmode: ‘multiplecells’,
    editmode: ‘click’,
    rowdetails: true,
    rowsheight: 20,
    columnsreorder: true,
    groupable: true,
    altrows: true,
    columns:
    { text: ‘Company’, datafield: ‘CompanyId’, columntype: ‘dropdownlist’,
    displayfield: ‘CompanyName’, datafield: ‘CompanyId’, width: 150,
    editor.jqxDropDownList
    ({ source: dataAdapater1, displayMember: ‘CompanyName’,
    valueMember: ‘CompanyId’
    { text: ‘Department’, datafield: ‘DepartmentId’, columntype: ‘dropdownlist’,
    displayfield: ‘DepartmentName’, datafield: ‘DepartmentId’, width: 150,
    ({ source: dataAdapater2, displayMember: ‘DepartmentName’,
    valueMember: ‘DepartmentId’
    { text: ‘Code’, datafield: ‘EmployeeCode’, width: 60 },
    { text: ‘Name’, datafield: ‘EmployeeName’, width: 170 },
    { text: ‘Mobile No’, datafield: ‘MobileNo’, width: 110 },
    { text: ‘Email’, datafield: ‘EmailId’, width: 150 },
    { text: ‘If Active’, datafield: ‘Active’, width: 80 },
    Keshavan
    /html>
    Dropdown in Grid – Usage Issue #17886
    Hi Keshavan,
    No, there is no limit on the number of adapters. However, I found out that you have syntax errors in your initialization like ‘,’ for last array and object items.
    Example: { text: ‘If Active’, datafield: ‘Active’, width: 80 },
    and url: ‘Employee/GetEmployees’,
    In addition, the current version is jQWidgets 2.8. If you use a different version, I suggest upgrading to the latest one.
