jQuery UI Widgets › Forums › Grid › Drag and Drop and everpresentrow
Tagged: #jqwidgets-grid, drag and drop, grid, javascript grid, jquery grid
This topic contains 1 reply, has 2 voices, and was last updated by Hristo 8 years, 1 month ago.
I have grid with everpresentrow function to add new row.
When I add drag and drop capability on rendered function:rendered: function (type) { // select all grid cells. var gridCells = $('#jqxGrid').find('.jqx-grid-cell'); // initialize the jqxDragDrop plug-in. Set its drop target to the second Grid. gridCells.jqxDragDrop({ appendTo: 'body', dragZIndex: 99999, dropAction: 'none', initFeedback: function (feedback) { feedback.height(25); }, dropTarget: $('#jqxGrid1'), revert: true }); gridCells.off('dragStart'); gridCells.off('dragEnd'); gridCells.off('dropTargetEnter'); gridCells.off('dropTargetLeave'); // disable revert when the dragged cell is over the second Grid. gridCells.on('dropTargetEnter', function () { gridCells.jqxDragDrop({ revert: false }); }); // enable revert when the dragged cell is outside the second Grid. gridCells.on('dropTargetLeave', function () { gridCells.jqxDragDrop({ revert: true }); }); // initialize the dragged object. gridCells.on('dragStart', function (event) { var value = $(this).text(); var position = $.jqx.position(event.args); var cell = $("#jqxGrid").jqxGrid('getcellatposition', position.left, position.top); $(this).jqxDragDrop('data', { value: value }); }); // set the new cell value when the dragged cell is dropped over the second Grid. gridCells.on('dragEnd', function (event) { var value = $(this).text(); var position = $.jqx.position(event.args); var cell = $("#jqxGrid1").jqxGrid('getcellatposition', position.left, position.top); if (cell != null) { $("#jqxGrid1").jqxGrid('setcellvalue', cell.row, cell.column, value); } }); },
I cannot add new row using everpresentrow, cannot even click on that row. Everything works if I remove all rendered code…
Hello arkgroup,
Thank you for the feedback.
I would suggest you if you want to try a workaround – create empty fields above (or under) the Grid as an alternative of the everpresentrow.
Also, you could use empty Grid sticked with no rows and columns, just with one row to the Master Grid.
Add recorded data to the Master Grid –var value = $('#jqxGrid').jqxGrid('addrow', rowid, {});
.Best Regards,
Hristo HristovjQWidgets team
