jQuery UI Widgets Forums Lists ListBox double or right click event
This topic contains 4 replies, has 2 voices, and was last updated by  Dimitar 11 years, 8 months ago.
  • double or right click event #30119
    jon74
    Hi all,
    is there a way to bind double click event on a listbox item? or also other list widget?
    I’ve seen that there’s no event other than common “select”, or “change” and so on…
    I tried with jQuery binding but it attaches it to the widget DIV element, and not to the single item.
    Jon
    double or right click event #30120
    Hello Jon,
    Here is how to bind to the jQuery dblclick event on a listbox item:
    <body>
    <div id='content'>
    var theme = "";
    var source = [
    "Affogato",
    "Americano",
    "Bicerin",
    "Breve",
    "Café Bombón",
    "Café au lait",
    "Caffé Corretto",
    "Café Crema",
    "Caffé Latte",
    "Caffé macchiato",
    "Café mélange",
    "Coffee milk",
    "Cafe mocha",
    "Cappuccino",
    "Carajillo",
    "Cortado",
    "Cuban espresso",
    "Espresso",
    "Eiskaffee",
    "The Flat White",
    "Frappuccino",
    "Galao",
    "Greek frappé coffee",
    "Iced Coffee",
    "Indian filter coffee",
    "Instant coffee",
    "Irish coffee",
    "Liqueur coffee"
    // Create a jqxListBox
    $("#jqxWidget").jqxListBox({ selectedIndex: 3, source: source, width: 200, height: 250, theme: theme });
    $("#jqxWidget .jqx-listitem-element").dblclick(function () {
    alert("Double click");
    <div id='jqxWidget'>
    double or right click event #30129
    jon74
    thanks a lot Dimitar!
    double or right click event #30168
    jon74
    hmmm it does not work to me 🙁
    double or right click event #30205
    Hi Jon,
    Does the example not work for you? Have you updated to jQWidgets version 3.0.3?
