jQuery UI Widgets › Forums › Grid › Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down
This topic contains 5 replies, has 2 voices, and was last updated by ivailo 9 years, 12 months ago.
July 20, 2015 at 8:46 pm Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down #73965
We have an Editable Grid with horizontal scrollbar.
The problem : when we double click on Grid’s horizontal scrollbar, the vertical scrollbar move down. Also, the cell behind horizontal scrollbar is selected. We have the same problem, if you try de move the horizontal scrollbar.This problem is only detected in this version jQWidgets 3.8.1 with EDITABLE grid. The older version have a normal behavior.
Thanks lots
<html lang=”en”>
<title id=’Description’>In order to enter in edit mode, select a grid cell and start typing, “Click” or press the “F2” key. You
can also navigate through the cells using the keyboard arrows or with the “Tab” and “Shift + Tab” key combinations. To cancel the cell editing, press the “Esc” key. To save
the changes press the “Enter” key or select another Grid cell. Pressing the ‘Space’ key when a checkbox cell is selected will toggle the check state.</title>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.edit.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxcalendar.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxnumberinput.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxdatetimeinput.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/globalization/globalize.js”></script>
<script type=”text/javascript” src=”generatedata.js”></script>
var data = generatedata(200);var source =
localdata: data,
datatype: “array”,
// and with parameter false if the synchronization failder.
commit(true);
datafields:
{ name: ‘available’, type: ‘bool’ },
{ name: ‘price’, type: ‘number’ },
{ name: ‘date’, type: ‘date’ }
};var dataAdapter = new $.jqx.dataAdapter(source);
// initialize jqxGrid
$(“#jqxgrid”).jqxGrid(
width: 850,
enabletooltips: true,
{ text: ‘First Name’, columntype: ‘textbox’, datafield: ‘firstname’, width: 120 },
{ text: ‘Last Name’, datafield: ‘lastname’, columntype: ‘textbox’, width: 120 },
{ text: ‘Product’, columntype: ‘dropdownlist’, datafield: ‘productname’, width: 195 },
{ text: ‘Available’, datafield: ‘available’, columntype: ‘checkbox’, width: 167 },
text: ‘Ship Date’, datafield: ‘date’, columntype: ‘datetimeinput’, width: 110, align: ‘right’, cellsalign: ‘right’, cellsformat: ‘d’,
validation: function (cell, value) {
if (value == “”)
return true;var year = value.getFullYear();
if (year >= 2015) {
return { result: false, message: “Ship Date should be before 1/1/2015” };
return true;
text: ‘Quantity’, datafield: ‘quantity’, width: 170, align: ‘right’, cellsalign: ‘right’, columntype: ‘numberinput’,
if (value < 0 || value > 150) {
return { result: false, message: “Quantity should be in the 0-150 interval” };
return true;
editor.jqxNumberInput({ decimalDigits: 0, digits: 3 });
{ text: ‘Price’, datafield: ‘price’, align: ‘right’, cellsalign: ‘right’, cellsformat: ‘c2’, columntype: ‘numberinput’,
if (value < 0 || value > 15) {
return { result: false, message: “Price should be in the 0-15 interval” };
return true;
editor.jqxNumberInput({ digits: 3 });
});// events
$(“#jqxgrid”).on(‘cellbeginedit’, function (event) {
var args = event.args;
$(“#cellbegineditevent”).text(“Event Type: cellbeginedit, Column: ” + args.datafield + “, Row: ” + (1 + args.rowindex) + “, Value: ” + args.value);
});$(“#jqxgrid”).on(‘cellendedit’, function (event) {
$(“#cellendeditevent”).text(“Event Type: cellendedit, Column: ” + args.datafield + “, Row: ” + (1 + args.rowindex) + “, Value: ” + args.value);
<body class=’default’>
<div id=’jqxWidget’>
<div id=”jqxgrid”></div>
<div style=”font-size: 12px; font-family: Verdana, Geneva, ‘DejaVu Sans’, sans-serif; margin-top: 30px;”>
<div id=”cellbegineditevent”></div>
<div style=”margin-top: 10px;” id=”cellendeditevent”></div>
`July 21, 2015 at 5:36 am Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down #73973Hi tazi,
Thanks for the feedback.
We will fix this issue in some of the next releases.Best Regards,
Ivailo IvanovjQWidgets Team
http://www.jqwidgets.comJuly 21, 2015 at 6:53 am Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down #73980Thanks Ivailo for your feedback.
1.) Could you please supply a workaround to fix this problem until the next release.
2.) Please confirm, in which release this issue will be fixed (the release date) ?Best regards,
TaziJuly 21, 2015 at 1:03 pm Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down #73996Hi tazi,
Unfortunately right now we don’t have a workaround about this issue.
We will investigate the problem, generated this issue, and fix it soon as possible.Best Regards,
http://www.jqwidgets.comAugust 3, 2015 at 9:24 am Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down #74423Hi,
Could you please give us a feed back about your investigation ?
Best Rergards,
Tazi.August 3, 2015 at 4:01 pm Double click on Grid’s horizontal scrollbar implies vertical scrollbar move down #74461Hi Tazi,
The investigation is still in process.
You can check the new releases and fixes here.Best Regards,
