jQuery UI Widgets Forums Plugins AngularJS Does it work with ngRoute?
This topic contains 5 replies, has 2 voices, and was last updated by  Peter Stoev 10 years, 1 month ago.
  • Does it work with ngRoute? #70213
    activefolder
    Blocked
    View:
    <jqx-button jqx-settings="settings">{{buttonData}}</jqx-button>
    <span>{{buttonData}}</span>
    Cotroller:
    $scope.buttonData = "Click me";
    Span binds correctly but button shows ‘{{buttonData}}’ without ngRoute both works correctly!
    Does it work with ngRoute? #70221
    Hi activefolder,
    If you would like to report something, then I suggest you to share a complete sample which demonstrates it.
    Does it work with ngRoute? #70232
    activefolder
    Blocked
    No thanks, I switched to “”
    There are a lots of issue with jqwidgets
    Does it work with ngRoute? #70238
    Hi activefolder,
    We have 1000+ demos without issues so it’s strange that you experience a lot of issues. May be you did not read the documentation and did not look at the samples to learn how to use this product. Anyway. Have a good day!
    Does it work with ngRoute? #70241
    activefolder
    Blocked
    Demos always work nicely but only Productions have bug
    Show me a sample with angular routing (ngroute)
    Show me a sample that JavaScript reference (jQWidgets) are bottom of page (not at top or header)!
    Does it work with ngRoute? #70242
    Hi activefolder,
    If you experience an issue, post a sample which demonstrates it, jsfiddle.net, etc. The issue may be is not in our scripts.
    Here’s a sample where the scripts are at the bottom and the sample works fine.
    <html ng-app="demoApp">
        <title id="Description">jqxButton directive for AngularJS</title>
        <link rel="stylesheet" type="text/css" href="../../jqwidgets/styles/jqx.base.css" />
    <body>
        <div ng-controller="demoController">
            <jqx-button jqx-instance="buttonInstance" jqx-height="settings.height" jqx-width="settings.width">Button</jqx-button>
            <jqx-toggle-button jqx-settings="settings">Toggle Button</jqx-toggle-button>
            <br />
            <br>
            <jqx-check-box ng-model="checked">Click me to toggle the disabled state</jqx-check-box>
            <br />
            <br />
            <jqx-button jqx-on-click="onClick(event)" ng-disabled="checked" jqx-settings="settings"><span>{{buttonData.text}}</span></jqx-button>
        <script type="text/javascript" src="../../scripts/angular.min.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxangular.js"></script>
            var demoApp = angular.module("demoApp", ["jqwidgets"]);
            demoApp.controller("demoController", function ($scope) {
                $scope.buttonInstance = {};
                $scope.settings =
                    width: 150,
                    height: 30
                // called when a button is clicked.
                $scope.onClick = function (event) {
                    $scope.buttonData.text = "Clicked";
                $scope.buttonData = {
                    text: "Click me"
                $scope.checked = true;
    You already wrote that you have switched to a different product, so I will close this Topic.
