jQuery UI Widgets Forums Layouts Docking docking resize problem
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 5 months ago.
  • docking resize problem #46055
    castt
    I have jqxSplitter with two panels. Left one is menu and the right one is content.
    Following this algorithm:
    1. Create docking window inside jqxSplitter panel.
    This goes to right panel
        <div id="docking">
                                    <div>
                                        <div id="window3">
                                            <div>
                                                Zodiac
                                                <div id="zodiak">
                                                        <h3>Leo</h3>
                                                        <span style="font-size: 11px">
    Individuals born under the zodiac signof Leo are very...</span>
    and aplying jqwidgets:
    $('#docking').jqxDocking({ theme: theme, orientation: 'horizontal', width: '100%', mode: 'docked' });
    Try to collapse/expand left panel, docking width working as expected, 100% filled the right panel.
    2. delete docking using $('#docking').jqxDocking('destroy');
    3. Add the same html and try to create jqxDocking object again with the same javascript code:
    4. Try to collapse/open left panel again, now jqxDocking is not changing it size (now it fixed size) as it was first time.
    Looking at your source code of jqxDocking, after creating jqxDocking object second time this part stopped getting triggered to perform proper resizing:
    In _addEventListeners function:
    a.jqx.utilities.resize(this.host, function () {
                    c._performLayout()
    Please let me know if you want me to provide additional code of jqxSplitter initialization. However jqxGrid works fine when repeat the same algorithm.
    docking resize problem #46086
    Hi castt,
    We will test that scenario and if we find something wrong, we will add a work item about it.
    Thanks for the feedback!
