jQuery UI Widgets Forums General Discussions Navigation Tabs div scrollTop problem
This topic contains 6 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 4 months ago.
  • div scrollTop problem #17216
    willy70
    Hi, I get the following problem with a control jqxTabs, and would be grateful if someone could be of help.
    I put the control on a page, with various tabs dynamically created based on a template.
    The control works fine, but when I switch from one tab to another, the positions of all scrollTop div content on them will be lost.
    Does anyone know how to fix it?
    div scrollTop problem #17224
    Dear willy70,
    Could you please provide a small sample which demonstrates your issue with jqxTabs?
    div scrollTop problem #17342
    willy70
    This is an example page that I created to show the problem.
    When I move from one tab to another, the scroll position of the div content in the previous tab is lost.
    How can I solve this problem?
    I used jqwidgets version 2.7
    $(function() {
    $(‘#div_Tabs’).jqxTabs(
    { width: 400, scrollPosition: ‘both’, padding: 1,
    reorder: true, showCloseButtons: true, theme: ‘black’
    tab 1
    tab 2
    tab 3
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    div scrollTop problem #17343
    willy70
    $(function() {
    tab 1
    tab 2
    tab 3
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    div scrollTop problem #17344
    willy70
    I can not insert HTML code…
    How it works?
    div scrollTop problem #17345
    willy70
    $(function() {
    tab 1
    tab 2
    tab 3
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 1
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 2
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    prova 3
    div scrollTop problem #17396
    Hi willy70,
    1. To insert HTML in the Forum, please take a look at this topic: http://www.jqwidgets.com/community/topic/code-formatting/
    2. When you switch tabs, we set display: none to the old tab and display: block to the new tab. When you navigate to the old tab again, we set display:block. That resets the DIV tag’s scrolling position. As a solution, you may use the jqxPanel inside your tabs. It will keep your scrolling position.
    Below is a sample solution:
    // Create jqxTabs.
    $('#jqxTabs').jqxTabs({
    width: '90%', height: 200, position: 'top', initTabContent: function (index) {
    switch (index) {
    case 0:
    $("#panel1").jqxPanel({ width: '100%', height: '100%' });
    break;
    case 1:
    $("#panel2").jqxPanel({ width: '100%', height: '100%' });
    break;
    <div id='jqxWidget'>
    <div id='jqxTabs'>
    <ul>
    <li style="margin-left: 30px;">Node.js</li>
    <li>JavaServer Pages</li>
    </ul>
    <div id="panel1">
    Node.js is an event-driven I/O server-side JavaScript environment based on V8. It
    is intended for writing scalable network programs such as web servers. It was created
    by Ryan Dahl in 2009, and its growth is sponsored by Joyent, which employs Dahl.
    Similar environments written in other programming languages include Twisted for
    Python, Perl Object Environment for Perl, libevent for C and EventMachine for Ruby.
    Unlike most JavaScript, it is not executed in a web browser, but is instead a form
    of server-side JavaScript. Node.js implements some CommonJS specifications. Node.js
    includes a REPL environment for interactive testing.
    <div id="panel2">
    JavaServer Pages (JSP) is a Java technology that helps software developers serve
    dynamically generated web pages based on HTML, XML, or other document types. Released
    in 1999 as Sun's answer to ASP and PHP,[citation needed] JSP was designed to address
    the perception that the Java programming environment didn't provide developers with
    enough support for the Web. To deploy and run, a compatible web server with servlet
    container is required. The Java Servlet and the JavaServer Pages (JSP) specifications
    from Sun Microsystems and the JCP (Java Community Process) must both be met by the
    container.
    Hope this helps you.
