jQuery UI Widgets Forums Grid Display problem with "showvalidationpopup"
This topic contains 2 replies, has 2 voices, and was last updated by  mallepaddi 11 years, 8 months ago.
  • Display problem with "showvalidationpopup" #31558
    mallepaddi
    Hi
    I am using “showvalidationpopup” to show error messages, it’s working fine when the grid doesn;t have vertical scroll bar and message showing at correct place …
    code : $(“#jqxgrid”).jqxGrid(‘showvalidationpopup’, event.args.rowindex, “qty”, “Enter Quantity for selected product.”);
    But the problem was with grid having vertical scroll bar, if i scroll and editing any row after scrolling, message not showing at targeted row level but somewhere at top which is not visible.
    For testing purpose, better to work on last item once scrolled ..
    please help
    Hi mallepaddi,
    Please, provide a sample which demonstrates your scenario. The fact that you use “event.args.rowindex” as an event argument means that you dynamically display that validation on some event and a sample would help us to understand what you try to achieve.
    mallepaddi
    Hi
    It’s simple, popup message should be shown when :
    Validation in on checkbox status … if user selects “checkbox” but Quantity field value is ZERO then popup should be like “Enter value ..”
    It’s all working .. but …
    When you have more rows, when you scroll and doing above action not showing popup at right place …
    var theme = ‘web’;
    var editedRows = new Array();
    var source = {
    { name: ‘selected’, type: ‘bool’ },
    { name: ‘productcode’, type: ‘string’ },
    { name: ‘description’, type: ‘string’ },
    { name: ‘supplier’, type: ‘string’ },
    { name: ‘price’, type: ‘string’ },
    { name: ‘uom’, type: ‘string’ },
    { name: ‘qty’, type: ‘string’ }
    url: ‘Products.json’,
    var cellsrenderer = function (row, column, value, defaultHtml) {
    return “”;
    loadError: function (xhr, status, error) { alert(‘Data load error !!!’);}
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid({
    width:’650′,
    height:’400′,
    selectionmode: ‘none’,
    editmode: ‘click’,
    enablehover: true,
    { text: ”, datafield: ‘selected’, menu: false, sortable: false, editable: true, columntype: ‘checkbox’, width: 10 ,
    renderer: function () {
    return ‘
    { text: ‘Code’, datafield: ‘productcode’, editable: false,width: 70},
    { text: ‘Description’, datafield: ‘description’, editable: false, width: 235},
    { text: ‘Supplier’, datafield: ‘supplier’, editable: false, width: 125},
    { text: ‘Price / Unit’, datafield: ‘price’, editable: false, width: 70, align: ‘right’, cellsalign: ‘right’},
    { text: ‘Qty’, datafield: ‘qty’, width: 70, editable: true, cellsalign: ‘right’, align: ‘center’, columntype: ‘numberinput’, cellsrenderer:cellsrenderer},
    { text: ‘UoM’, datafield: ‘uom’, columntype: ‘textbox’, editable: false}
    $(“#jqxgrid”).on(‘cellvaluechanged’, function (event) {
    var row = event.args.rowindex;
    var dataField = event.args.datafield;
    var value = event.args.value
    var datarow = $(“#jqxgrid”).jqxGrid(‘getrowdata’, row);
    //if checkbox checked
    if(value === true){
    $(“#jqxgrid”).jqxGrid(‘selectrow’, event.args.rowindex);
    if (parseInt(datarow.qty) <= 0) {
    $("#jqxgrid").jqxGrid('showvalidationpopup', event.args.rowindex, "qty", "Enter Quantity for selected product.");
