jQuery UI Widgets Forums Grid Display column headers dynamically
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 7 months ago.
  • Display column headers dynamically #63853
    sri1241
    How to display the column headers and column names dynamically in grid using array.
    var commonList = [];
    	var columns = [];
    	var firstList = [{ "text": "Id ", "datafield": "id"},
    	                    { "text": "Name", "datafield": "name"}];
    	var secondList = [{ "text": "Second Id ", "datafield": "id"},
    	                    { "text": "Second Name", "datafield": "name"}];
    	SampleService.setParameter = function(pageFrom){
    		columns = new Array();
    		if(pageFrom=="First") {
    			commonList = firstList ;
    		}else if (pageFrom=="Second"){
    			commonList = SecondList;
    	     for (var i = 0; i < commonList.length; i++) {
    	         columns.push({ text: commonList[i].text, datafield: commonList[i].datafield });
    SampleService.SampleSource = {
    		        {name:'id'},
    			{name:'name'}
    	SampleService.SampleAdapter = new $.jqx.dataAdapter(SampleService.SampleSource);
    	SampleService.SampleGrid = {
    		width : '99.8%',
    		showheader : true,
    		columnsheight : 30,
    		columnsreorder : true,
    		source : SampleService.SampleAdapter,
    		columns : columns
    Please help.
    Display column headers dynamically #63866
    Hi sri1241,
    These should be set during the Grid’s initialization. Then you can change properties and set them to other values.
