jQuery UI Widgets Forums Navigation Tabs Destroy problem of a grid in a tab
This topic contains 2 replies, has 2 voices, and was last updated by  cosostones 11 years, 4 months ago.
  • Destroy problem of a grid in a tab #48447
    cosostones
    In my application I use jqxTabs and jqxGrid. When I want to destroy a grid that has not been shown (in the second tab) I got an error.
    I host a sample with a screenhot : http://sdrv.ms/1bsLSmb.
    Regards.
    Destroy problem of a grid in a tab #48465
    Hi cosostones,
    If the Grid was created in the way we demonstrated in our demo, you would not experience such problem. In general, it is not possible to destroy something which is not yet rendered.
    Here’s a modification of your code which ensures that the Grid is destroyed only if it is initialized:
        <title id='Description'>This demo shows how to integrate jqxTabs with other widgets.
        </title>
        <link rel="stylesheet" href="jqx.base.css" type="text/css" />
        <script type="text/javascript" src="jquery.min.js"></script>
        <script type="text/javascript" src="jqxcore.js"></script>
        <script type="text/javascript" src="jqxdata.js"></script>
        <script type="text/javascript" src="jqxbuttons.js"></script>
        <script type="text/javascript" src="jqxscrollbar.js"></script>
        <script type="text/javascript" src="jqxtabs.js"></script>
        <script type="text/javascript" src="jqxgrid.js"></script>
        <script type="text/javascript" src="jqxgrid.selection.js"></script>
        <script type="text/javascript" src="jqxgrid.edit.js"></script>
                var initGrid = function () {
                    $("#jqxGrid").jqxGrid(
                        width: '100%',
                        height: '84%',editable: true,
                            { text: 'Date', datafield: 'Date', cellsformat: 'd', width: 250 },
                            { text: 'NASDAQ', datafield: 'NASDAQ' }
    			var initialized = false;
                $('#jqxTabs').jqxTabs({ width: 600, height: 560, initTabContent: function(index){
    				if (index == 1)
    					initialized = true;
    					initGrid();
    			$("#btnTest").click(function(evt){
    				if (initialized)
    					$("#jqxGrid").jqxGrid("destroy");
        <div id='jqxWidget'>
            <div id='jqxTabs'>
                <ul>
                    <li style="margin-left: 30px;">
                        <div style="height: 20px; margin-top: 5px;">
                            <div style="float: left;">
                                <img width="16" height="16" src="../../images/catalogicon.png" />
                            <div style="margin-left: 4px; vertical-align: middle; text-align: center; float: left;">
                                US Indexes</div>
                    </li>
                    <li>
                                <img width="16" height="16" src="../../images/pieicon.png" />
                                NASDAQ compared to S&P 500</div>
                    </li>
                </ul>
                    <div id='jqxChart' style="width: 100%; height: 100%">
    					blabla
                    <div id="jqxGrid">
                    <div style="margin-top: 10px; height: 15%;">
                        The S&P 500 index finished 2011 less than a point away from where it ended 2010
                        -- 0.04 points down to be exact. That's the smallest annual change in history. At
                        its peak in April, the S&P had climbed more than 8%. But by October, at the lowest
                        levels of the year, it was down more than 12%. The Nasdaq, meanwhile, lost 1.8%
                        for the year.</div>
    	<input type='button' id='btnTest' value="destroy grid"/>
    Destroy problem of a grid in a tab #48503
    cosostones
    Hello Peter,
    Okay thanks for the clarification, it works in this way.
    Regards.
